I have made this thread Some way to fit or stretch a FF result automatically into a square
In the Color Control Image placement you can convert any external source image to square using the FIT or STRETCH or FILL option Color control does not have any node connection, so you can not connect any component to the color control to be able to fit, stretch or fill with that result a square So I wonder if there could be a upgraded or new color control component that can have a node input where you can connect internal FF components results to this color control, so instead of only being able to use external images, it could also be able to use internal images result made inside FF |
| Posted: May 10, 2016 1:36 am | ||
Perhaps a Trim component where you can take out the transparent or same-color edges like in Photoshop?
Internally FF already has a 1x1 square (or an infinite plane, depending how you want to look at it) as the drawing area, so a color-control type fill, fit or stretch wouldn't do anything with it. |
| Posted: May 10, 2016 6:19 am | ||
33,849 Registered Users
+12 new in 30 days!
+7 new in 7 days!
15,392 Topics
+44 new in year!
