xirja
Idididoll Forcabbage
If an option to the Command Line Renderer to output progressive rendered blocks (https://www.filterforge.com/forum/read...TID=13905) isn't doable, then the only other option is to submit to the Command Line Renderer, blocks.
It would be extremely helpful to be able to fix the Distance Based components, so that the input image size would have no effect.
The only option at this point is to manually redo all the math for the components to suit a new size. Unless the 'Size, pixel' slider could be set to multiples larger than the input image.
So the Distance Based problem is as described at the bottom of the post here (https://www.filterforge.com/forum/read...&TID=3752)
11 unregistered users.
