The "Reset Default Values" option might be poorly named. Once a user has set his/her own default values on a component, it appears that the option should revert the component back to those very user default values! What it does instead now is overwrite user values with the factory default values that FF ships with, which seems counter-intuitive.
My suggestion: Make a clear distinction between user defaults and factory defaults in the option names, i.e.
- Rename "Save Default Values" to "Save User Default".
- Rename "Reset Default Values" to "Restore User Default". Firing that option reverts the component's settings back to the user default.
- Introduce an additional "Restore Factory Default" option. Firing that option reverts the component's settings back to the factory default.
