ivanB
Filter Forge 4.014 Prof.Ed. Using "Color Control" component with "Allow Images" enabled, where can I see the whole file name of a loaded image? Long file names are displayed with the beginning of the file name visible and few dots.....for the rest of the name. So when I load a particular filter preset, FF loads also a particular image but its often long file name is only partially visible! It does not show in Recent Images either. Where and how can I find the whole file name?
Note: Some image file names are long as they also contain references to filters and presets previously used for creating those images. Filter names may vary only by the ending where number for the preset used is attached - BUT - not visible!
Thanks for help, Ivan
This also happens on Windows, and with Filter Forge 5. When you first load the image to create the preset, the file appears in "recent images". But load the preset later on, and the image does not appear in "recent images", like Ivan said. I thought "reload image" would help, but it doesn't. Neither does copying/pasting, or entering/exiting the filter editor.
My suggestion is to add a feature similar to right-clicking a filter (in the preview list) and selecting "Locate File". Instead, you right-click the color control preview (image or file name), and in addition to "Copy Image" and "Paste Image", there would be a "Locate File" option.
