this one is a bit tricky, too, because again, you can sort of put components together to sort of do this... sort of. what's really needed is a component that, for the sake of demonstrating here, if you had a contour map, it would smooth all the contours down into gradual, on a gradient, slopes. it's not a blur, per se, and it's not a median or percentile. it's based on height of pixels and rather than give a hard line like a contour map, you'd simply smooth that down to the surrounding area based on radius control.
if something like this... or this, already exists, kindly let me know.
33,849 Registered Users
+12 new in 30 days!
+7 new in 7 days!
15,392 Topics
+44 new in year!
