Neil Blevins
Posts: 27 |
A pretty common noise type available in other programs is "Turbulence". Turbulence is really just a modification of a base noise type. Take whatever base noise you want, put its range into -1 to 1, take the absolute value of that, and you get turbulence (note, this formula happens before fractal iterations are applied).
So for example, here's regular Perlin Noise:
and here it is after Turbulence is applied...
This can be applied to Worley Noise (Cellular), any any other noise type. With it you can achieve some great effects...
While it is possible to build a filterforge network to do this, it would be great if we could just have this in the Noise Profile of all the noise types as a preset, so is there any chance we could have it added? Thanks for listening! - Neil |
| Posted: May 8, 2015 2:39 pm | ||||
xirja
In the mean time, before custom components we can drag and drop, I've found a custom components folder helpful for cut and paste operations at least.
But actually, a V curve attached to the perlin profile isn't that much trouble. _____________________________________________________
| Posted: May 8, 2015 11:45 pm | ||||
Neil Blevins
Posts: 27 |
Ya, I'm actually considering making a filter that contains all of my custom components, so I can go in there and copy and paste them to WIP filters. Again, until we can drag and drop custom components from some sort of custom area in the components shelf, in which case I'll use that instead.
- Neil |
| Posted: May 9, 2015 8:43 pm | ||||
| Posted: May 11, 2015 5:30 am | ||||
| Posted: May 11, 2015 5:31 am | ||||
Neil Blevins
Posts: 27 |
Well, it only adds one more entry into a drop down menu with 5 existing entries, so I don't see it adding that much more complexity, but I guess everyone has their own definition. For me adding an extra curve component is more complexity than adding it to the profile list, but we'll see if they'll consider it. - Neil |
| Posted: May 11, 2015 5:11 pm | ||||
Ah, yes if you add it as a curve preset then you're right. I thought you wanted a checkbox that worked with any curve.
| Posted: May 12, 2015 5:57 am | ||||
Neil Blevins
Posts: 27 |
Ah ok, that makes more sense. Ya, don't want that, just want it added to the already existing profile dropdown. - Neil |
| Posted: May 12, 2015 5:54 pm | ||||
| David Roberson |
I'd be happy just to be able to see the guts of the profile curves *inside* the noise components. Several are unique to those components, and the icons for them are too small to use as a guide for making those curves usable *outside* with other components.
I've looked for snippets that might feature those curves, but no luck! |
| Posted: February 19, 2018 9:26 pm | ||||
| Posted: February 20, 2018 4:35 am | ||||
| David Roberson |
Very interesting! Are the components in the xml portable to ffxml? Seems easier to cut-and-paste, and then grab the components out of the filter you did it in.
Thanks! |
| Posted: February 20, 2018 4:41 am | ||||
Dunno - try saving some curves in a new filter and see how the parameters look
| Posted: February 20, 2018 5:02 am | ||||
That was easy
Here is a filter with all build in profile curves from all components All Build In Curves.ffxml |
| Posted: February 20, 2018 5:18 am | ||||
| David Roberson |
Wow! That's handy! Thank you!
| Posted: February 20, 2018 4:39 pm | ||||
| David Roberson |
Aw, nutz!
I'm not having any luck replicating the trick, either. |
| Posted: February 20, 2018 6:07 pm | ||||
| David Roberson |
Well, I've gone over the markup and proofed it for errors. There's got to be something I'm missing, 'cuz I keep getting an "invalid format" response when I try to open it in Filter Forge.
You can look it over if you like. Maybe you can spot what I've done wrong... _Snip Internal Curves.ffxml |
| Posted: February 20, 2018 7:23 pm | ||||
| David Roberson |
Worked it out the hard way. Comparing the result to the previous one, the main difference that stands out is the way some values are stored. Looks like float values were required (but not used internally).
_Snip Internal Profiles.ffxml |
| Posted: February 20, 2018 8:58 pm | ||||
| David Roberson |
I do hope you stay interested in turbulence noise as a topic. I've been trying to work out a flow turbulance distortion method, but so far it's more of a notion than a project. I kinda know how I'd do it in Photoshop manually, with a few spiral distortions set on the margin of opposing horizontal displacements, over a few iterations.
I'm just not at the point where I know how I'd need to implement it in FF. |
| Posted: February 20, 2018 9:02 pm | ||||
