i love the frames component but recently i've found myself looking for some more versatility from it. specifically, i'd love to be able to OUTPUT the individual controls from the component separately from the main output.
we've got lots of good inputs to frames but only one output. i'd love to be able to output JUST the inside frame or just the outside frame or just the margins. the color parts i'm not worried about, but those 3 would make great additional nodes on the output side of the frames component. dont change the internal rendering. do that the same, but just allow for the individual parts of the component to be outputted separately after the internal rendering is done.
Just make another frame with similar settings. Its too confusing to start making components with multiple outputs.
Just set the colors of the parts you don't need to Alpha = 100, that would do the trick.
ah, how simple! thanks, vlad smile:)
Ken
CameraKen
Filters: 16
Hi Craig
I am sure you worked it out. But if not there is a filter showing the method here
http://www.filterforge.com/filters/1838-v3.html
Ken.
thanks, ken smile:)
31 unregistered users.
