| jffe |
I can't seem to set a minimum level for remapping the Repeat function of a Profile Gradient module. Only the Int Slider works, the normal kind doesn't, and remapping the Int Slider only allows me *step* settings, which do not accomplish setting a min-max like remapping a normal slider does. I guess unless there's a work-around for that, it would be a feature request.
jffe Filter Forger |
| Posted: December 25, 2006 6:14 pm | ||
| Posted: December 25, 2006 7:52 pm | ||
Ok I updated the snippet a bit and the following explanation should help make sense of it...
-Decide your min/max range such as 13-26. -Take the max range, subtract the min range, and add one. For example 26-13+1=14. Remember this number. -Click on the IntSlider named 'Repeat'. In the 'Max Value' field enter the number you just calculated. -Click on the blend component. -Click the forground color icon to set your max repeat level using the B slider of HSB. -Click the background color icon to set your min repeat level using the B slider of HSB. That's all there is to it! Minimum Repeat.ffxml |
| Posted: December 25, 2006 8:39 pm | ||
Here's another version that uses standard sliders for the user control (the other version uses an IntSlider)
Minimum Repeat 2.ffxml |
| Posted: December 25, 2006 11:40 pm | ||
| jffe |
Wow, you made me a snippet, that was very nice of you, thanks much.
| Posted: December 26, 2006 12:05 am | ||
Can you post your filter? I'm pretty sure I can get it to work.
| Posted: December 26, 2006 12:06 am | ||
