KeithS
Filters: 7
I was very disappointed to discover that when I updated my filter, all the explanations disappeared!!! why is that ? it's an update.
I would have to re-type the explanation on how to use it each time ?????
that just does not make sense !
please have the filter save meta data !!!
Sorry that I do not understand what you mean.
All the explanations dissapeared from where? The about tab? The description inside the filter editor? The update part of the filter?
When did they disappear? After the update that was sent to the filter library? or was an update in your own computer?
Everything that you write in the description available in the Filter info is always kept inside the filter, and is not deleted unless you delete it yourself.
Everything that you write in the update notes of the filter info is kept only once for the update and you have to write it for each update.
the metadata is kept inside the keywords part
Please see the Filter Info Help page for more information
11 unregistered users.
