| Austy51 |
I have searched all through the components to find the best way to get an embossing effect. I am wanting to create the same effect that the surface renders create with a height map, but I want to create it in a component so I could then edit it afterwards with other components. Now I know it would be really difficult to turn the surface render into a component, but all it would be is something simple like the Emboss filter in Photoshop. It would a simple version with only the shadows and highlights. It would be able to turn this:
Into This |
| Posted: January 10, 2014 12:07 am | ||||
I think that what you mean is that you want an emboss component that could do it WITHOUT using the surface filter, because you can´t add any other components and keep processing the image AFTER the results component.
I have requested an alternative replacement to the results component so you could use all the many emboss filters available WITHOUT having to use the results component as the end of the filter and so you could keep processing the image Add new component emulating the "surface type" of the result component |
| Posted: January 10, 2014 3:29 am | ||||
| Austy51 |
I read your post and I get exactly what you mean by that, and that is what I would want too. But I also understand why it was rejected. I think it is because they use a different engine for the surface component, and that is why it needs to be a post process component. But what I am asking for here is something that is not the same as the surface component, but still can render a height map just in a more simple way.
| Posted: January 10, 2014 7:59 am | ||||
I think that maybe is possible to make an emboss effect that can be done WITHOUT using the surface results component, because I have made this Heavy Snow filter that includes some kind of emboss and lighting using a height map AND it does not use the surface results component With this filter to lower the amount of "Snow" or emboss, the easiest way is to use the "Size,pixels" slider at the bottom, as this will reduce much the overall effect, there is another way modifying the settings to get a low effect. Maybe there are other alternative ways to get the effect you want using the surface result |
| Posted: January 10, 2014 8:40 am | ||||
| Austy51 |
I will have to check that out to see what you did. But the embossing I am talking about would not be similar to the surface effect. All it would render is a bump maps highlights and shadows. It would not implement the lighting map that surface uses. The closest I have gotten so far is using derivative, but it is not the same desired effect I am looking for.
| Posted: January 10, 2014 9:34 am | ||||
| Austy51 |
I saw what you did with that filter, and I can see that as being an effective way of getting that result. I spent some time messing around today and I came up with a few different ways using mainly RGB math. (BTW I don't know hot to script that well, but I imagine it would not be difficult to reproduce these methods with a script component)
I also uploaded a snippet filter to look at. It is called Emboss Snippet, and it shows all the methods I used. It probably isn't on the site yet. this first image is of the surface filter
This is a method I used using a slanted gradient and a refraction comp. But is creates a light and dark area in the corners
And this is the best method so far. I used ArcTangent2 and had one input be the image and the other be a very slight offset of the image. It still doesn't look like the surface component, but it does closely relate to the Photoshop emboss filter, which is the look I originally wanted.
I have more methods I used in the snippet, but these are the best. Overall it would still make it easier just to make this into an independent component. Which is why this post was on the wishlist to begin with. |
| Posted: January 10, 2014 2:40 pm | ||||
12 unregistered users.
