| Burt |
I think it would be useful to have a Path or Strand component. The idea being that you could generate a 'strand' with either square or smooth turns which would either go from some random start point to a random end point the component generates -trying to avoid overlaps - or would seek to start at a random point and after some turns return to the same point forming a closed path. It would be useful to be able to set the minimum number of turnings or corners. (note red squares are just to indicate points though I guess an option to show/hide points might also be useful).
This could be useful for example to generate a 'solution' for a maze pattern and should have many other creative uses. |
| Posted: January 7, 2014 1:43 pm | ||
Does anything in this thread interest you? Try ThreeDee's "scribble".
| Posted: January 8, 2014 9:10 am | ||
| Burt |
Thanks Indigo Ray, they are interesting and will play with them.
| Posted: January 8, 2014 12:05 pm | ||
