Alright, I am treading unknown territory here, as we obviously know next to nothing about how Particles are going to be implemented.
The limited info on particles hints at two basic component types that we will probably see: Particle Shape components (i.e. NGons/Stars, Text hopefully) and a Particle Bomber/Generator component that will distribute the particle shapes across the image in various modes (say... in grids, inside of primitive shapes, at random, according to regions defined by image luma/chroma/alpha etc.). Now, I am hoping the devs are three steps ahead of me here. There could be the usual types of force-fields (like directional forces, turbulence, vortex, friction, etc.) and special ones like image and gradient based force-fields. These are basically maps that would contrict particle trails to certain regions or along certain features of the image. A bricks component used in this fashion could force the particles to form trails roughly along the mortar lines, allowing effects such as moss growing or blood running between the bricks. If the particles had the ability to spawn additional particles along their path, the creation of grass, furs and hair might also be possible. In effect, the particles become procedural brushes, and their trails the brush strokes, all defined by the forces acting on the particle system. I'll probably get killed for mentioning something that can be done in other software, but I'll do it anyway: Project Dogwaffle's 'Optipustics' are a good example of what I am trying to convey here. They are painted instead of procedurally placed, but they do make spectacular use of image forcefields. Well, that's my ideas and hopes for Particles... for the moment! --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: November 25, 2006 7:41 pm | ||||||
A nice example of painting with particles on an image derived force-field. Notice the palette in the bottom left corner where the 'force-field-image' is displayed...
![]() --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: November 25, 2006 8:48 pm | ||||||
WOW
| Posted: November 26, 2006 2:29 am | ||||||
Administrator |
Yes, I've been thinking about that recently. A possible problem with the ideas you're suggesting is of course the speed -- especially when complex particle placement is combined with a high number of generated particles. We'll have to keep that in mind.
| Posted: November 27, 2006 3:10 am | ||||||
I agree. While even complex optipustics-strokes can be painted interactively, generating an interactive preview of the whole 'paint job' at once would certainly not be all that speedy, even with a proxy view that used a largely reduced particle count. I dare not think about what would happen if the user dared pipe a complex particle setup through a highpass... Still, completely procedural particle brushes are not too commonplace in programs these days, so this might be an area well worth delving into, especially if you plan to introduce animation capabilities into FF someday. Just speculating about all the nice things we could do with those particles makes me feel all warm and fuzzy inside... --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: November 27, 2006 5:25 am | ||||||
Administrator |
The Darksim guys are working on a program called Tactile Ink, it will have procedural brushes: http://www.darksim.com/html/tactile_ink.html |
| Posted: November 27, 2006 5:31 am | ||||||
Administrator |
Animated particles is an entirely different story -- we'll have to watch out for temporal discontinuities, which aren't a problem for a non-animated package. |
| Posted: November 27, 2006 5:34 am | ||||||
Administrator |
I can't find any forcefield controls in PD 3.5 demo -- where are they? |
| Posted: November 27, 2006 7:20 am | ||||||
They are on the Optipustics panel (see image below).
To use forcefields you first need to open a forcefield image, then fire the forcefield plugin via the Optipustics palette. Finally, swap the image buffers via the layers palette, so that your image ends up in the forcefield buffer! That's how it's done in the full version at least, the demo might be feature restricted... ![]() --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: November 27, 2006 9:42 am | ||||||
Administrator |
| Posted: November 27, 2006 9:48 am | ||||||
Yes and no. I am using PD Pro 3.5 as well, but the full version. I guess the demo is restricted then.
Still, if you are willing to dig into it, the commercial version is VERY cheap. --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: November 27, 2006 9:51 am | ||||||
More on the topic of bombers...
It would be nice to have a special 'Bomber Image' component in addition to the standard 'Image' component, so that we can load in any image to become a particle. Furthermore, I'm hoping that the bomber tools won't be introduced as a separate component 'category' (with a completely new type of input required), but rather work like the pattern generators (i.e. similar to Kaleidoskope) in that they accept normal 'green' map inputs. However, with all the complexity that could be built into a 2D particle system (just think about introducing forcefields) and the UI space that this would consume, I'm really interested how the devs will implement these bombers. Will we have an 'all-in-one' bomber component with a large amount of controls, or will we assemble these systems using dedicated shape, placement, forcefield and output components? --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: May 8, 2007 5:50 am | ||||||
Administrator |
Definitely not. Both the particles and bombers will be regular map components. Introducing a new component/input type would ruin learnability.
Yes, I'd prefer it to be this way. It would have a map input for a particle (or even multiple particles in one input, but I'm not sure about this one), and mappable inputs for placement, size, rotation, stretch, opacity, density, etc. Maybe something like this: Particle Noise: Map Component -- Particle: color map -- Background: color map -- Size: grayscale map -- Stretch: grayscale map -- Angle: grayscale map -- Opacity: grayscale map -- Density: grayscale map -- Roughness: grayscale map -- Details: slider -- Fill Mode: combobox -- Variation: random seed Particle Grid: Map Component -- ... -- ... -- ... |
| Posted: May 8, 2007 6:36 am | ||||||
Excellent! The fact that all the parameters can be mapped has me in very high hopes.
Regarding the bomber controls, what exactly does 'Roughness' do? --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: May 8, 2007 6:51 am | ||||||
Administrator |
If they were unmapped, that would result in a pretty dumb bomber, wouldn't it?
Exactly the same what it does in all noises (together with Details). Details controls the number of octaves, Roughness controls their relative transparency. I hope that we will be able to use the layered octaves approach in the bomber as well. I think this is feasible, but there may be problems with brightness normalization. |
| Posted: May 8, 2007 8:30 am | ||||||
Well, this solution is certainly superior to other systems where you can just specify a random deviation percentage for each particle attribute. Say you'd set Particle Size to 1 and the Size Deviation to 25%, then particles would have sizes ranging from 0,75 to 1,25. This is inherently less powerful than mapping the attribute in the first place (because deviation percentages would essentially just be random noises hardwired to the map inputs) -- hence my enthusiasm. --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: May 8, 2007 8:49 am | ||||||
| Posted: May 8, 2007 2:05 pm | ||||||
Administrator |
http://freespace.virgin.net/hugo.elia...perlin.htm http://eldeann7.chez-alice.fr/perlin_noise/index.htm |
| Posted: May 9, 2007 8:47 am | ||||||
Looking at the parameters again, where does the user set the number of particles that are created? The 'Density' parameter - as I understand it - sort of does this, but it does not allow precise control over particle counts, does it? Black areas spawn zero particles, but how many are spawned in white areas? And what if I wanted exactly 10 particles spawned randomly within a white circle on black ground? Can I set a total particle count for any given bomber component? --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: May 9, 2007 1:20 pm | ||||||
thanks, vlad. that first link explained it just fine and that's pretty much what i thought. just wanted to make sure.
however, i'm not sure why he's defining frequency as 1/wavelength. the way i was taught, frequency is the number of cycles per second. his version looks like the inverse of that. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: May 9, 2007 2:35 pm | ||||||
Some more questions...
- The 'Fill Mode' controls the mode that the particles are blended with? - 'Angle' controls rotation around the Z axis I presume. Will there be X and Y rotation as well? --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: May 10, 2007 6:39 am | ||||||
Administrator |
Yes, I'd like to see this parameter implemented.
No point, since the same effect can be achieved via size/stretch. |
| Posted: May 10, 2007 7:55 am | ||||||
Administrator |
Don't think this is a good idea, at least for a Particle Noise component. This might be implemented in other bombers (for example, a particle grid or even a specific placement component). |
| Posted: May 10, 2007 7:57 am | ||||||
IMO the the ability to place an explicitely specified amount of particles within an exactly defined area is indispensible. Of course I can't say whether this makes sense for a 'Particle Noise', but there should definitely be a dedicated component that does this.
| Posted: May 10, 2007 8:30 am | ||||||
Indeed! Blend modes for particles are indispensible, IMO. --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: May 10, 2007 8:31 am | ||||||
Btw... forcefields and/or particle trails are off the list? Or will we see dedicated components for these, like 'particle gravity', 'particle vortex', 'particle turbulence'? These would be nice for creating such effects as wet graffiti paint trails, grime running down walls, grass growing in cracks, furry surfaces etc.
| Posted: May 11, 2007 5:34 am | ||||||
This is being added right after the Mac version, right???
| Posted: September 4, 2007 8:47 am | ||||||
Nah. Bombers will be introduced in the next update, of course! ![]() --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: September 5, 2007 6:31 am | ||||||
Okay then.....I'll hold Vlad to that promise
| Posted: September 5, 2007 10:22 am | ||||||
i'm totally curious about what's going to be in (and not be in) version II. i do hope they do an open beta again.
| Posted: September 5, 2007 12:42 pm | ||||||
Administrator |
Yes, we'll do an open beta -- our first beta was very helpful.
According to the current plan, the major items to be included into 2.0 are bombers, shapes, full range of math components with unclamped output, local search for filters, and grouping of components in the Editor. Bombers and shapes are relatively easy to do. Math components may pose certain difficulty since they will require control components with numeric input, which, in turn, may require serious infrastructural changes. Grouping of components within the Editor is also a difficult task. |
| Posted: September 6, 2007 3:33 am | ||||||
cool. thanks for that, vladimir!
i cant even begin to imagine what a large program like this entails as far as code, but glad you're doing it. i do hope version 1.xx is doing well sales-wise. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: September 6, 2007 8:36 am | ||||||
Wow, that sounds great!!!
I don't mean to sound like a "Greedy Gretchen".....but by any chance are "lockable controls" going to be added to the next release??? I know that I sound like a broken record Steve
| Posted: September 6, 2007 10:12 am | ||||||
Administrator |
This is a non-critical item, an enhancement, and we don't have a solid plan regarding these yet. If time and resources allow, we'll implement some of them. |
| Posted: September 7, 2007 7:09 am | ||||||
It's just one of my personal "love to have" features
To be honest, I'm just happy to see FF continuing to grow.....more goodies and a new beta release planned.....life is good!!! Steve
| Posted: September 7, 2007 8:36 am | ||||||
