Vladimir have confirmed that it will not be possible to include a components bar inside FF 4.0, but I had an idea as alternative to this instead that I think and suposse would be easier to make (I really do not know as I am not a programmer) rather than building the components bar inside FF editor.
Alternative to component bar - Save and Load groups I thought that there could be an alternative to have a component bar inside FF Editor and is to be able to save and load individual groups as components, so you could save a group as component to the hard drive and then load back when you need it, I think that this alternative way may be easier than building the custom components bar inside FF editor, at least for FF 4.0
Well this is a simplistic version as for me it can be even worse than this as this is what I do when having to copy something - Save the filter you are working on - Close editor - Remember which filter have you stored the group that you want - Search for that filter - Select it and open in FF editor - Select group to copy - Check that the Size pixels global setting is at Maximum value (or what value it has) - exit editor - Search again for the filter that you was working on - Open it in Editor - Check that the Size pixels global setting is at Maximum value (or the same value as the original) - Paste the group in the filter and agree that all this work above breaks sometimes the flow of the work and have to remember what you have been doing. - Remember that you also need another thing you had in another filter and repeat ALL the above steps again This is a very bad workflow IF SAVE AND LOAD GROUPS WOULD BE POSSIBLE Instead of all the many steps above it would be much easier While you are working on your filter you will ONLY: 1 - Open load group and search for the saved group you want 2 - Load the group into your filter 3 - continue working 4 - if you need another just repeat the ONLY 2 FIRST STEPS above This way you would not have to save the filter you are working on and exit filter editor and would not break the workflow |
| Posted: October 5, 2013 12:46 am | ||||||||
| Posted: October 5, 2013 1:08 am | ||||||||
Sorry that I have put this thread wrongly, as the text is NOT what I wanted to put and I by mistake hit the return key and it was posted and then Skybase wrote so I can´t make it right.
Please do not post or make any comment on this thread, do it on the new fixed and good one, thanks New one --> FF 4.0 Groups - Be able to save and load groups individually |
| Posted: October 5, 2013 2:35 am | ||||||||
