angelize
Would this be possible? One use for an extra result component would be to create reflective filters with reflection images. For example I've been playing with one that when applied to text or shapes creates a variety of metal surfaces and an extra result component would allow me to create a secondary filter that would use a colour component to allow the user to upload any image to use as a reflection and then blend the two results together. This is not possible with only one result component because if the reflection image is blended in before the result component then it adds to the surface colour rather than overlays on top. Another use would be surface filters composed of two different surfaces with different reflective or metallic qualities
| Posted: July 23, 2013 2:47 am | ||
xirja
+1 I've found that to be needed too.
Maybe this will help solve part of the problem: http://www.filterforge.com/more/help/...mport.html At the bottom of this post Crapadilla says it has been rejected: http://www.filterforge.com/forum/read...9&TID=9607 and in the feature request wiki: https://www.filterforge.com/wiki/index...e_Wishlist [2.0] Illumination/Lighting component. (Partially implemented via the Derivative component.) then there are also two unanswered scripting requests: http://www.filterforge.com/forum/read...&TID=10119 http://www.filterforge.com/forum/read...8&TID=7747 _____________________________________________________
| Posted: July 24, 2013 8:00 am | ||
angelize
Thank you this has been very helpful and I have also discovered that I can use FF to save as an openHDR file I'm going to need to play!
| Posted: July 24, 2013 1:42 pm | ||
13 unregistered users.
