voldemort
voldemort
Filters: 649
Sometimes your not sure what catagory a filter is in under your downloaded ones or its name search within the program would be nice. It would save time from having to hunt down that elusive filter
Indeed. I am currently using the web library for that and click on 'open in filter forge' once I have found my filter since it also works for those that are already downloaded. Still, it feels a bit like a workaround. smile:D
Great idea, it would be even cooler if it worked like FireFox where you only need to type the first letter and its already coming up with results.
Torley
Second Lifer
I agree a lot with this; several times already and some months after this was posted, I find myself lost in all the filters I've recently downloaded.
There should also be an option to sort by author, so I can view filters by a given user in Filter Forge, similar to how we can do it on this very forum. smile:)
I'm enjoying using Filter Forge to create http://torley.com/textures
Yes, that's the way it should be done.
for me, all i need is one folder for the entire library IF and ONLY IF, i can make my own file tree within FF where i can then organize things how i want, making folders, deleting folders, moving filters and so on. put a search on THAT as well and i'm happy.
Torley
Second Lifer
Vladimir, I wonder what happened there — you quoted uberzev but it credited the quote to me. Odd!
Corrected.
Move along... Mispost! smile;)
61 unregistered users.
