Burt
Random Old Guy
Wacky idea but sometimes when I create textures in Photoshop I will retain a 'frame' and remake the middle. This will allow you to create multiple seamless terrain tile or brick wall variations (see attached) and they will all tile well together. So a component that allowed you to 'freeze' a certain amount of pixels of the edge then generate a new 'middle' or some way to generate multiple tiles with matching edges or the ability to generate transition tiles might be useful.
Sharandra
Filter Forge Addict
Lol you beat me to this tip! I was just gonna post the same thing smile:D
Burt
Random Old Guy
Well that's ok then because some of my other suggestions turned out to be existing features. smile:blush:
Sharandra
Filter Forge Addict
Hehe, well if they are already features that means they are good suggestions! smile:-)
I just reread your original post and realised that it was a feature request and not a tip.
You can do this in a filter like in Photoshop by masking out the middle pretty much in the same way using a frame or gradient. Then connect a slider to the middle components variation.
Sharandra
Filter Forge Addict
example
Burt
Random Old Guy
Ah, ok I see. I wasn't sure that the edges would blend but the gradient frame edges ease the transition. I guess with bricks it could work too. Not sure if stone or plaster would but now that I know it can be done I will test it - and I guess I'll stop adding feature suggestions for a bit. smile:blush:
Sharandra
Filter Forge Addict
well I didn´t blend the bricks themselves, but the color variations and the damage details. That was enough in this case.
But yeah, I guess this trick doesn´t work in every case. I have yet to make more filters using it to be able to tell what works and what doesn´t.
your example from above should work tho, if you have the hole in the middle and just change its shape.
Sharandra
Filter Forge Addict
Masking out bricks:
I think this also works with noises which have solid fill.
Burt
Random Old Guy
Great example! Will play with it when I get back home. smile:)
