I have seen that there are a few (or many) Filter Forgers that know and have the experience to code and know scripting and programming and think that would be good for FF to be able to allow that they could customize and modify the components available and so it would be possible to add the missing parts they need or modify them to their needs.
AND also would be good to be able to MAKE YOUR OWN COMPONENTS inside FF so you could get much more and make more things than now are not possible and they could make more things with FF
PERHAPS THIS NEW MODIFIED COMPONENTS OR NEWLY CREATED WOULD NOT BE ALLOWED IN THE LIBRARY
I think that perhaps to allow to modify the components and make your own ones could be a problem if you want to submit a filter to the library, but perhaps the easy fix would be not to allow this kind of different components other than the ones factory made, and it would only be possible to share them in the forums.
REDUCE SOME OF THE FEATURE WISHLIST THIS WAY
There are already many request asking the developers of FF Inc. for new components or to modify the existing ones.
Well, if it would be allowed to modify available components and create your own ones, it would be possible to reduce the requests and the work for developers and this would allow to FF to grow much higher.
I'd be pretty happy just with the ability to RENAME the Script components and add them into a CUSTOM SCRIPT COMPONENTS section in the Components panel.
Well, I think that many FF users like you could make many interesting and useful scripts and new components that would be very interesting and helpful for many things as many of you have done already with many great snippets.
