chairman
chairman
Hello Community!
I recently upgraded my CS 5 to CS 5.5. Now I'm using Photoshop 5.1 64Bit on a Windows 7 system.
Since that change FF3 (3.007) unfortunately does not show up in Photoshop's filter menu any more.
I was searching the internet and in this forum for solutions. But all attempts too solve this problem by myself failed.
- I have already deinstalled FF3 and installed it again. => no result
- I copied the whole Filter Forge programm folder to ADOBE/PLUGINS/FILTERS = > no result
- I reseted the Photoshop configuration by pressing SHIFT+ALT+STRG while opening PS => no result
- Finally I contacted the Filter Form Team via the contact form on this site => I did not get any reply at all
I'm not satisfied with the support from FilterForge. I bought!!! FilterForge to use it with and especially out of Photoshop.
But FilterForge is a good software and I would like to use it further on. Therefore I would be very glad about any help to solve the
problem.
Support team doesn't work weekends, so you should get a reply on monday, probably.
Other than that, Photoshop installs both 64bit and 32bit versions on your computer.
Copy the FF folder to the plugin directory of both Photoshop versions, just to be sure.
Hope this solves your problem. If not, maybe someone else here has more ideas smile:)
21 unregistered users.
