Valery
Hello!
When i try to download filter, programm show error smile:?:
Bella
Filter Forge, Inc.
Strange. Looks like temporary problems with your Internet connection. Does it reoccur?
Valery
Yes, it reoccur.
I try on two computer with direct connection to internet, and its reoccur smile:(
Then i change option in connection setting and this did not help.
Bella
Filter Forge, Inc.
Valery, please make sure you can connect to filterforge.net via the HTTPS protocol (443 TCP port). As a test, try to get to https://filterforge.net/ via your Internet browser (from the computer on which Filter Forge is installed).
Valery
HI Bella!
I connect to filterforge.net via the HTTPS protocol normal and i see message "Hello".
I understand that when i try to reciev new filter, bug reoccur.
When i click filter which already be in forge base, program normally show me this filter.
I can not get new filter smile:cry:
Valery.
Bella
Filter Forge, Inc.
Valery, the fact that you can establish a connection via HTTPS through your browser most probably means that the problem is local - it exists on your computer only.
Do you have Firewall? (By default, Win XP uses Windows Firewall.) If you have it, please check your firewall settings - make sure Filter Forge is allowed to access filterforge.net via HTTPS (443 TCP port).
If you are having problems with configuring your firewall, you can contact us via the contact form at http://www.filterforge.com/contact/
33,857 Registered Users
+44 new in year!
14 unregistered users.
