Anyone had any problems submitting a filter today?
I've been trying to submit a filter for a few hours now, and i keep getting the same error every time:
Everything else works, downloaded filters with no problem. Any ideas? |
| Posted: February 3, 2012 5:59 pm | ||||||
Still no go on uploading a filter...
Is it just me? Has anyone uploaded a new filter today? |
| Posted: February 4, 2012 3:43 pm | ||||||
I will try to upload my first 3 filters tomorrow Sunday, so I will be able to answer you when I do it and see if it works or not.
| Posted: February 4, 2012 4:26 pm | ||||||
Thanks buddy!
| Posted: February 4, 2012 4:32 pm | ||||||
Mardar
Morgantao, did you try rebooting your computer? When I have fail errors of any kind in FF this usually fixes it.
| Posted: February 4, 2012 5:04 pm | ||||||
| Gene S Morgan |
I've been having the same problem lately as well. I get the same error message. Tried a couple of different Wifi spots and even dial-up. Has anyone tried to reinstall FF?
| Posted: February 4, 2012 11:49 pm | ||||||
I think the cause is the fact that there are many submissions. It's happened before and it does not depend on us, but FF. I do not think we should uninstall and reinstall FF. Traffic will eventually decrease.
visit https://gisoft.ca |
| Posted: February 5, 2012 1:01 pm | ||||||
cfree68
I tried again with a filter I've tried many times on many computers.. no go. Then I tried another filter I had done and it worked. Tried the one that had failed so many times, changing out all the names and description.. Still would not work.. Same error.
Not sure what the issue is. colin Fizgig |
| Posted: February 5, 2012 10:35 pm | ||||||
Weekend is over, let's hope FF inc. will have an answer\fix for us soon
| Posted: February 6, 2012 1:58 am | ||||||
I said I was going to try to submit my own filters, they are now finished, but have yet to try them better and see if there coud be any error on different images, as they work well with built-in images but probably not so well with other kind of images.
So It will take a little more time. And also so it probably will be fixed this problem and will not have problems when submitting |
| Posted: February 6, 2012 3:06 am | ||||||
| Gene S Morgan |
Have any of you folks figured out this problem yet? I still am unable to upload filters. There are new filters in the library, so everybody is not having the problem. I've got the coolest filters ever that I want to upload, (OK, I'm probably streching the true there a bit) and I thought that someone from FF would have commented on this by now. Maybe It's just me ......
| Posted: February 11, 2012 10:31 pm | ||||||
Is this not fixed yet ???
Yes, I thought that as there have been new filters in these days, this problem have been already solved.
OH! the coolest filter ever ? I want to see them, please help to fix this so the upload can be possible and we can see these coolest filters I am already preparing my own cool filters that I hope I will be releasing this next week. |
| Posted: February 12, 2012 2:53 am | ||||||
Gene, the way I managed to solve this is simply create the filter from scratch, and maybe changing a bit the components.
In my filter I added a little feature, after rebuilding the whole thing again as a new filter. I also changed the description and the keywords a bit. Seemed to do the trick. I don't know what causes this bug, and seems FF inc. doesn't have a simple explanation (or any explanation for that matter) as to why this happens. Maybe if we all take it to the bug report forum it will get more attention from the dev team. |
| Posted: February 12, 2012 7:11 am | ||||||
lipebianc
I wish there was a simple 'submission server status' somewhere on the website (something like a discrete 'online/'offline' colored warning), so authors will be aware if the should wait to submit their work another time.
"From the moment we are born, we start being filtered..." |
| Posted: February 12, 2012 1:14 pm | ||||||
Posts: 3505 |
Gene S Morgan, has the issue been resolved?
| Posted: February 13, 2012 2:37 am | ||||||
| Gene S Morgan |
GMM .... For me,no. It sounds like some folks have found some kind of work around. I'm going to try with a different filter tonight as Morgantao suggested. I'm on dial-up, so it will take awhile. I will try with a new filter and if that works I will try to redo the old ones. This has gone on with me for about 4 weeks. It started when I uploade 2 other filters and the third one got the error message and have not been able to upload since. Any ideas?
| Posted: February 13, 2012 7:57 pm | ||||||
| Gene S Morgan |
GMM .... OK, I'm just not getting this. I uploaded a very simple filter of mine and it seemed to be accepted. But, then I tried one I had tried before and got the same old error message. My filters are never very complicated or big. I don't understand why some are Ok and others are not. Any suggestions would be greatly appriciated ...
| Posted: February 13, 2012 9:22 pm | ||||||
maybe if we upload the filters that give us the error to the forum and have the dev team look at them there will be a solution to this bug.
GMM, should I upload a filter sample here, or should I create a new thread for it in the bugs and problems forum? |
| Posted: February 14, 2012 1:02 am | ||||||
Posts: 3505 |
Morgantao, Gene S Morgan: what OS and Filter Forge version do you use?
Please don't create a new thread for the same issue – I will move this one to the corresponding forum. And yes, please post the problem filters here or email them to the support team. |
| Posted: February 14, 2012 1:49 am | ||||||
I'm on a win7 64 machine, using lateset FF3 pro.
Here's a filter that I couldn't upload, so I just recreated it from scratch (with a few minor changes): Ball Pit V2.ffxml |
| Posted: February 14, 2012 1:02 pm | ||||||
| Gene S Morgan |
GMM ... I'm sending my 2 filters that have failed to upload as you requested. I'm also on a win7 64 machine, using lateset FF3 pro. I run in 32 bit mode bacause I use Photo Shop 7. I had a thought about the timing of our uploads and maybe the date had something to do with the trouble. Morgantao changed his filters, but at the same time he resaved them changing the update file date. I'm going to try to upload a filter that I have resaved. It is worth a shot .... Thanks for trying to help us out .... Gene
Super Snoppy.ffxml |
| Posted: February 14, 2012 9:50 pm | ||||||
| Gene S Morgan |
GMM I found out the hard way I can't send a zip file. Here is the second filter.
Popcorn Stitch Crochet.ffxml |
| Posted: February 14, 2012 9:51 pm | ||||||
| Gene S Morgan |
My big idea of changing the save date didn't work .......
| Posted: February 14, 2012 10:30 pm | ||||||
I have already sent 2 filters with the submit wizard and had no problems, so it must depend on the submit way of managing the filters and not that it is not working.
| Posted: February 15, 2012 1:24 am | ||||||
Posts: 3505 |
Morgantao, Gene: thanks for your input. We've fixed something on the server side, please try to resubmit.
| Posted: February 15, 2012 6:21 am | ||||||
I have already uploaded a different version of that filter, so I can't test it now, but let's see if Gene can upload his
Next time I'll upload a filter I'll tell you if something went wrong. Thanks for the help GMM, and thanks for the quick fix |
| Posted: February 15, 2012 9:07 am | ||||||
| Gene S Morgan |
I emailed my problem, but couldn't send bug report. I downloaded new update and installed and now FF will not run at all. I will attach bur report if I can.... Oops forgot I'm on IPad......
| Posted: February 15, 2012 11:53 am | ||||||
| Gene S Morgan |
Hope this works ... attached is bug report ...It don't like that file so I will cut and paste .....
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd"> <ht ml> <head> <title>Filter Forge Bug Report</title> <met a http-equiv="Content-Type" content="text/html; charset=utf-8"> <st yle type="text/css"> HTML { margin:0; padding:0;} body { font-family: Arial, Geneva, sans-serif; margin:0; padding:0; font-size:small; background-color:#848892; text-align:center; } .container { text-align:center; margin-right:auto; margin-left:auto; background-color:#FFF; width:750px; } .topline{ width:750px; color:#d5d5d7; font-size:85%; font-family:Verdana, Arial, Geneva, sans-serif; text-align:center; margin-right:auto; margin-left:auto; } .language { float:left; padding:1em 0 1em; } Hope that works ...... |
| Posted: February 15, 2012 11:59 am | ||||||
| Gene S Morgan |
Finally got new update working and now everything has been smooth sailing again. I can upload filters once more. Thanks very much GMM. You really saved the day for us ...Gene
| Posted: February 16, 2012 9:18 pm | ||||||
20 unregistered users.
