| voldemort |
Not all controls appear in the end filter
If I go into edit mode all the controls are there with unique names and propper connects but they dont appear in the end interface or the order of controls menu this happes on about 5 of my filters since they are checked as use Remapping the editor still seems to randomize theese elements but its frustrating that they arent in the interface since it disallows fine tweaking of the end result lets all whine for a wine port |
| Posted: October 17, 2006 9:52 pm | ||
Administrator |
To appear on the Controls tab, all control components must "have a route" to the Result component -- if a control doesn't affect the result, it isn't displayed in the interface. In other words, a subtree to which a control component is connected must itself be connected to the result. Is this the case? If not, could you post the filter here?
| Posted: October 18, 2006 3:24 am | ||
| voldemort |
Im sorry I cant believe that I missed your post here considering how much this concerns me
http://www.filterforge.com/filters/1335.html blended beins alive I have 6 colors that can be remapped and all have propper outputs and was approved for submission but when you look at the controls only 4 appear??? this has happened before and I just started over from scratch but I redid this one 3 times with no change in the contol status not sure why lets all whine for a wine port |
| Posted: October 19, 2006 10:09 am | ||
Administrator |
We looked into this -- as I suspected, the controls aren't shown because they "don't have a route" to the Result component (read my previous post above).
| Posted: October 19, 2006 11:09 am | ||
| voldemort |
Ohh the shame of it --This is as bad as missing a semicolon in code for the 50th time I must have examined it 50 times but finally stepping away and seing it again I see my mistake thanks for the patience I appologize for the stupidity on my part and the inconvienence
Thanks lets all whine for a wine port |
| Posted: October 19, 2006 3:55 pm | ||
Igor Lorents
Posts: 39 |
Voldemort, you can select the Result component's subtree by choosing the Select Subtree option in the context menu to check whether the components are connected to Result or not.
| Posted: October 20, 2006 2:59 am | ||
14 unregistered users.
