Add a blend and fisheye doesn't work
fisheye.ffxml
It seems to work for me...
What were you trying to do?
if you use the switch I put in, to show the fisheye 1. direct 2. through a blend
I get the following results, first direct where the fisheye works
then secondly running through a blend, where the fisheye doesn't work, [this is a snippet out of a filter I'm working on that blends the fisheye with another effect], if it works for you even more weird smile:| smile:)
I think the problem is hat the checkbox is either 0% (only original) or 100% (only fisheye).
Replace the checkbox with a slider (no remapping) and see if when you take it left\right anything changes...
Or do what I did - remap the checkbox to 30% and 70%. I saw both fisheye and original.
Here's the 70% image:
And here's the 30% image:
the switch is only there to switch between the two versions for easier viewing of problem. The problem is before that in the first blend. Running through the first blend it is just 100% pass on of information. Your example shows a blending of the 2 inputs, this is not not making the fisheye work that run through the original blend. smile:)
Regular "blend" clips HDR colors. I think you want the "blend (HDR)" component.
Indigo spot on smile8) didn't cross my mind about the clipping smile:cry:
Thanks smile:)
I wasn't even looking at the first blend smile:|
Hey Morgantao I appreciate all your efforts to help - don't stop smile:beer:
41 unregistered users.
