photoman
Filters: 44
All of my submitted filters are not showing up in the update filter list. I want to update a filter but it is not in the submitted filters list. Only eight or nine are present.Any reason why they may not be showing up? smile:?:
Are you using the same login as you used for the previuos submissions?
photoman
Filters: 44
Using same log in and same info. Here is a copy of the filters showing up.
photoman
Filters: 44
Vladimir,
I see what the problem is. I wanted to update my Vignette filter using the frame component. It is listed in the effects category and not the texture category therefore it is not showing up. Only the filters listed in the texture category.
Can all submitted filters be listed instead of just texture and just effects. This would help in updating previously submitted filters.
Most likely, they don't show up because the current version doesn't allow you to update a Texture filter with an Effect filter and vice versa. This is already on our list. For now, you can delete the old filter (submit a request via our contact form) and submit the updated one as a new filter.
33,857 Registered Users
+44 new in year!
17 unregistered users.
