jitspoe
Filters: 27
I just started tinkering with the map script, and I tried to set the minimum value of an integer input to 0. It popped up a bubble that said "- Must be between 1 and 2^32-2." I changed the value back to 1, but the exclamation icon stayed next to the control input on the "Control Inputs" list, and when I click "OK", it states, "There are errors in entered data (denoted by red warning signs). All errors must be fixed before proceeding." If I make a different input invalid, the warning sign will move, but I still can't get out of the dialog. I did discover if you change the sort order, though, the (incorrect) warning will go away.
Jitspoe, we cannot reproduce this. I create a map script, create a new intslider input, change its minimum value to 0 and get the same error message, but I'm able to change it back to 1 and click OK.
If you follow some other steps to reproduce the error, please post them.
jitspoe
Filters: 27
I had more than one input, so maybe that's related. I'll see if I can create a repro case from scratch when I get back home.
jitspoe
Filters: 27
I'm able to repro this using the exact steps you described. Added an int slider, changed the value to 0, clicked OK, got the error, changed the value to 1, clicked OK, still got the error. Screenshot attached.
jitspoe, the bug has been confirmed and will be fixed in the next release.
22 unregistered users.
