Ken
CameraKen
Filters: 16
Hi
I have found a minor bug. Although it may be linked to the old version.
I was looking at my page curl filter to see how I could update it with the new Frame component. I deleted all the old code and added a gradient component.
As you can see the gradient should not look like this from these settings. It is like the repeat is set to 2, but you can see it is set to 1.
This only occurs in my page curl workspace. If I start a new filter then the problem disappears. So it may be related to the old version.
It is no problem. I just thought you may like to know about it.
Ken.
Make sure your "size, pixels" slider is set to max.
Ken
CameraKen
Filters: 16
Thanks uberzev.
That does solve the problem.smile:)
Ken.
33,857 Registered Users
+44 new in year!
15 unregistered users.
