Thomas Bishop
black_ronin1228
Operating system: Windows (6.0 build 6002) Service Pack 2
Physical memory: 3069 MB
Number of processors: 2, available: 2
Processor info: AMD Athlon™ 64 X2 Dual Core Processor 3800+, ~1081 MHz
Filter Forge x86-SSE2 2.008.17377.6226 Release-SSE2, July 06, 2010 12:31 [7/13/2010 4:13:16 AM Eastern Daylight Time]
Exception caught at thread 00001634 'DownloadStg 019A2458':
<class XFW::StateError> Could not get filter (2919, 1) XML.
<unknown file>(0) : <unknown function>()+0 at 00660AF2 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0065C37B in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0082A9F7 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00825A70 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 006559B5 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0081B86C in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 008286CC in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 7772D0E9 in C:\Windows\system32\kernel32.dll
<unknown file>(0) : <unknown function>()+0 at 775A19BB in C:\Windows\system32\ntdll.dll
<unknown file>(0) : <unknown function>()+0 at 775A198E in C:\Windows\system32\ntdll.dll
<unknown file>(0) : <unknown function>()+0 at 0081ED07 in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 001B:7771FBAE, SS:ESP 0023:0314F038, EBP 0314F088, FLAGS 00000212
CONTEXT_INTEGER: EAX 0314F038, EBX 00000002, ECX 00000003, EDX 00000000, ESI 00AA67B4, EDI 0314F0C8
CONTEXT_SEGMENTS: DS 0023, ES 0023, FS 003B, GS 0000
[Controls::Control] Exception occured while processing window message 0x0000000F(WM_PAINT) (0x00000000 0x00000000) for window 0012031E/0012031E, control: <class Controls::PushButton>@0D52DA30.
[Controls::Control] Exception occured while processing window message 0x00000111(WM_COMMAND) (0x00001438 0x0011029C) for window 000704B4/000704B4, control: <class Controls::Panel>@031CC668.
[Controls::Control] Exception occured while processing window message 0x00000202(WM_LBUTTONUP) (0x00000000 0x00090024) for window 0011029C/0011029C, control: <class Controls::PushButton>@03231438.
[Controls::Control] Exception occured while processing window message 0x0000000F(WM_PAINT) (0x00000000 0x00000000) for window 00130238/00130238, control: <class Controls::PushButton>@7E609E80.
[Controls::Control] Exception occured while processing window message 0x00000111(WM_COMMAND) (0x00007070 0x000203B2) for window 0015001E/0015001E, control: <class Controls::Panel>@04556320.
[Controls::Control] Exception occured while processing window message 0x00000202(WM_LBUTTONUP) (0x00000000 0x000E0042) for window 000203B2/000203B2, control: <class Controls::PushButton>@04557070.
Exception caught at thread 000016A4 'Application':
<class XFW::OSCallError> ::CreateDIBSection(context 19010D56, rectangle 0;75 0;24) (custom control <class Controls::PushButton>@0D52DA30) failed with error code 0x00000008: Not enough storage is available to process this command.
<unknown file>(0) : <unknown function>()+0 at 00577356 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0055FAD3 in Filter Forge x86-SSE2.exe
<unknown file>(0) : GetWindowLongW()+1203 at 76FFFD72 in C:\Windows\system32\user32.dll
<unknown file>(0) : GetWindowLongW()+1419 at 76FFFE4A in C:\Windows\system32\user32.dll
<unknown file>(0) : ReleaseDC()+125 at 76FF9D6A in C:\Windows\system32\user32.dll
<unknown file>(0) : WCSToMBEx()+204 at 76FF9F8D in C:\Windows\system32\user32.dll
<unknown file>(0) : <unknown function>()+0 at 775C5DAE in C:\Windows\system32\ntdll.dll
<unknown file>(0) : DispatchMessageW()+15 at 7700022B in C:\Windows\system32\user32.dll
<unknown file>(0) : <unknown function>()+0 at 00572B22 in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 001B:7771FBAE, SS:ESP 0023:00122688, EBP 001226D8, FLAGS 00000216
CONTEXT_INTEGER: EAX 00122688, EBX 0D52DA30, ECX 00000003, EDX 00000000, ESI 00AA67B4, EDI 00122718
Any ideas how to keep this from happening again? It hasn't happened again, just curious if it will help the code writers any. I couldn't submit it the normal way as I was offline, so I saved it.
Thomas
Thanks for reporting. We're aware of the issue.
