tardis420
<class XFW::ArgumentError> Failed to find class info for missing component class 'ScriptMap01'. Im trying to update my filters after installing them from the filter library backup I just recieved. No matter if I try to update indiviually or sel ect all I get the same error. Any advice to fix this.
This is windows 7 64 bit. I use it under photoshop plug in 32 or standalone as I need. Every thing has worked great up untill I installed back up library. I have updated filters before while using the beta with no issue. I have the bought version of 2.0 now. I have reinstalled/deleted user data fr om local roaming as well as reinstalled.
Totte
Übernerd
Filters: 107
OK, I've just seen this on Mac OS X as well.
If you remove the old filter by locating it and removing it from both ... System->Library and System>Cache it will downloads OK (but you need to download it , not update).
tardis420
I cant find this file on my system, ScriptMap01. Checked my AppData\Roaming\Filter Forge 2 and install folder. Unless you mean redownload the entire 1g backup file and reinstall. If I reinstall and start up I can go to the web page and download and update with no issue. I copy over the backup library I downloaded/bought and hit yes to replace any files as instructed. I start up filterforge, takes a bit longer now but expected as it builds library or cache. Things work fine. When I go to the update filter tab it lists 72 filters that need to be updated. I select all and update. It gives me the error message and nothing happens even though it says updating still. I gave it about an hour and canceled it. I try to update it one filter at a time. It gives me the same error no matter what filter I select to update. Will give it a go at redownloading the zip file today and try and install with a fresh install of filterforge with manual removal of appdata and install folder.
Totte
Übernerd
Filters: 107
The filter is named as usual, but contain a script component
11 unregistered users.
