I submitted this report already...I will also post it here so if you have not run accross this yet heres how to reproduce it..So avoid this combo altogether smile:(
NOTE THIS IS FOR VERSION 2 and 1 USERS
Create a new filter....Now in the empty workspace drag a slider component to the workspace......Name this control whatever you want....After naming this control
highlight that text.......Now with that text still highlighted go to the pull down menus at the top....When choosing the "edit" menu will result in a crash and the bug reporter showing its face... smile;) smile:)
The other menu choices work like normal.....
I found this because I was going to copy a control name with the menu instead of a shortcut.....Noooo I forgot to savethe filter when it happened smile:( smile:D
Actually I just checked VERSION1..This BUG is also in VERSION 1.....The same exact method is used to re-produce this.... smile:cry:
tigerAspect
Filters: 9
What.
Doesn't exist in the mac version, possibly because the most of the options in the Edit menu are greyed-out. smile:?:
It's impossible to copy/paste control names with the edit menu? That's bizarre. (and breaks Mac OS interface standards)
What a nice bug smile:-)
CFandM, thanks for reporting!
Igor Lorents
Filter Forge, Inc.
CFandM: Thank you for reporting the bug. I've already fixed it, and we're going to release the fix as soon as the next beta stage is ready. Can't say anything about the exact date, though.
tigerAspect: Yes, the grayed state of the Cut\Copy\Paste menu items for TextEdit controls is a known issue. And yes, we do understand that it goes against the typical Mac user experience.
This feature is on my todo list. But, unfortunately, it isn't a short-term task.
GMM wrote:
What a nice bug
hehe yep..The nice bugs are the ones that don't cause destruction.. smile;) smile:)
That was quick there Igor.. smile:) smile:pimp:
When I find those I will always report them..
Is it going to be a hotfix for Version1? Just curious..
Igor Lorents
Filter Forge, Inc.
Yeah, I've seen your bug report as well. Thx for it.
Sure, we're going to keep Version1 up-to-date till its last breath smile;)
hehe OK thanks Igor smile:)
