Heres an interesting one. While making a texture a component I did not use was the image component. I have a blend right before the result, when click on and checked there is no image yet looking at the result there is clearly an image. Here is a screen
It looks like it may have to do with the setting of the alpha. If you invert this you can see the image more clear.
onyXMaster
Filter Forge, Inc.
FF blends the result with image if no Image component is present in the filter itself. There will be an option to override this behavior in future release of FF.
33,857 Registered Users
+44 new in year!
16 unregistered users.
