Messages 1 - 45 of 59
kieron
Posts: 7 |
I have installed Filter Forge, but when I try to open it as a stand alone nothing happens. When I try to use the PhotoShop plugin nothing happens and PhotoShop freezes. I mean literally nothing happens, after I double click on the Filter Forge icon, I check the process list in Task Manager and nothing shows.
I have contacted support, but it has been several days and no reply other than the initial acknowledgment and a request for a copy of the running processes after trying to start FilterForge. Filter Forge looks great, but if I can't get it to run, it is pretty much useless to me. Details: I have a Boxxtech workstation: Vista Ultimate 64bit, 8GB ram, Adobe master collection. The FF plugin is of course in the 32bit version of PhotoShop. When I installed it, I shut down all antivirus/spyware programs and ran the install in administrator mode. I ordered this to use in a current project, but my deadline is coming up, if I can't resolve this I will have to return it and see if I can find some alternative. Any help would be greatly appreciated. kieron |
| Posted: August 14, 2009 3:35 am | ||||
Hi Kieron, this happens to me and I simple don't click the box, with in a short time FF opens normally on top.
| Posted: August 14, 2009 5:14 am | ||||
Administrator |
kieron, such questions are best addressed to the support team:
http://www.filterforge.com/contact/ (I already forwarded the link.) |
| Posted: August 14, 2009 11:04 am | ||||
kieron
Posts: 7 |
Thank you for the replies.
Carl, I wish it were that simple. I get nothing no box to click or to not click and no amount of waiting seems to help. About the longest I have waited for any response thus far was a little over two hours...and nothing. Vladimir, thanks for the referral. As I noted in the second paragraph of my initial post, I have tried contacting support without success and lately no responses at all to my follow up emails. As of this post I have received nothing from support in response to your forwarding of the link to this forum entry. Given that this is the "Bugs and Problems (Windows)" forum it seemed the appropriate venue to ask if others might have had a similar problem and what they did to overcome it. kieron |
| Posted: August 16, 2009 12:51 am | ||||
sorry couldn't be more help kieron
that seems a reasonable assumption |
| Posted: August 16, 2009 3:46 am | ||||
vladimir has stated elsewhere that FF will not work as a plugin on 64 bit o/s machines. it will run in standalone, but not as a plugin. hopefully, that's coming down the road sometime soon. that being said, i would have thought it would work in standalone. have you tried uninstalling and re-installing? sometimes, downloads of any kind will not be right. the only thing to do is uninstall whatever you have and download again, making sure you get the full byte size file and install it again. a file doesnt have to be very corrupt for it to not work at all or to work badly. i dont know that this is the case for you, that you have a bad/corrupt download, but i would think FF was tested for 32 bit vista and therefore shld work. there might also be program conflicts, being that vista is such a bloated hog (sorry, i'm just not a fan of bloatware). but, i'd start with the new download and install first. but, you might want to turn extra junk off before you try the new install, just in case. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: August 16, 2009 9:50 am | ||||
oh, and here's the quote from GMM, one of the filter forge staff:
| Posted: August 16, 2009 9:52 am | ||||
kieron
Posts: 7 |
Thanks for the replies Carl and Kraellin.
I have tried redownloading and reinstalling several times, with the same results. Bite size is consistent for all downloads. I have since received the CD and tried installing from that, same results. It does not open as a standalone. It appears in the filter list in the 32bit version of PS, but does not open from there either. I have seen the problems with most plugins not being ready for 64bit PS. I can live with that. I usually go to the 64bit only when I am doing something I expect to be really resource intensive. As more plugins become 64bit capable I will use the 64bit more. I think there may be something in Vista that is preventing the program from starting, but I have no clue what it might be. I have a lot of software for my design work, but I have never had this difficulty before. I almost wonder if Filter Forge is trying to write somewhere that Vista doesn't want it to. I wish I were more technically inclined. kieron |
| Posted: August 16, 2009 4:07 pm | ||||
yeah, it wouldnt surprise me if vista was blocking it somehow. i just dont know where, since i dont run vista. is there a compatibility mode in vista? you might try running it in that.
| Posted: August 17, 2009 1:54 pm | ||||
kieron
Posts: 7 |
Based on a suggestion in another thread, I rebooted to SAFE mode and was able to start FilterForge. So the culprit is Vista or at least one of the many functions it opens by default, but which one?
I will see what I can find out about a compatibility mode. kieron |
| Posted: August 20, 2009 5:35 am | ||||
well, i recently got my 64 bit vista and installed FF on it. it worked fine. no problems whatsoever. so, it could be another program you have running on the machine that's conflicting somehow.
| Posted: August 20, 2009 1:36 pm | ||||
| Eric MacArthur |
It's not a Vista problem... I had to install in safe mode on xp64 to get it to run.
I didn't not know that it did not work in PS with xp64. You have to search the forum before buying to find out??? Kinda stinks! |
| Posted: October 21, 2009 6:30 pm | ||||
| Eric MacArthur |
WOW even lamer!!!... It will not run unless it is in safe mode
| Posted: October 21, 2009 6:32 pm | ||||
| Eric MacArthur |
What do I do about this
| Posted: October 21, 2009 6:33 pm | ||||
| Eric MacArthur |
Dual Xeon 5355
16 gig ram 80gig Intel x-25M 8800 GTX Ultra xp64 HELP! |
| Posted: October 21, 2009 6:36 pm | ||||
Posts: 3505 |
Eric, do you use ZoneAlarm or Spyware Doctor?
Also, I assume you're using version 1.0 – right? |
| Posted: October 22, 2009 3:24 am | ||||
| Eric MacArthur |
My workstation has no security what so ever. I do not allow it onto the Net unless to authorize software.
Yes Version 1.0 or what ever I just downloaded from the main page yesterday. 1.x? |
| Posted: October 22, 2009 6:00 pm | ||||
Administrator |
The info about 64-bit support is listed in System Requirements: http://www.filterforge.com/download/requirements.html |
| Posted: October 23, 2009 3:28 am | ||||
| Eric MacArthur |
I see it now Vladimir, thank you.
Of course it doesn't run as standalone for me either |
| Posted: October 23, 2009 4:26 am | ||||
Posts: 3505 |
Eric, try to right-click Filter Forge.exe > select Run As Administrator.
| Posted: October 23, 2009 5:33 am | ||||
| Eric MacArthur |
That does not work. What next? |
| Posted: October 23, 2009 6:36 pm | ||||
| Eric MacArthur |
I also tried FF x86.exe and the SSE2.exe one, none of them will start.
| Posted: October 23, 2009 6:39 pm | ||||
| Eric MacArthur |
all email to support@filterforge.com has been rejected:
"This is an automatically generated Delivery Status Notification. Unable to deliver message to the following recipients, due to being unable to connect successfully to the destination mail server. support@filterforge.com --Forwarded Message Attachment-- From: xxxxxx@hotmail.com To: support@filterforge.com Subject: RE: (Case 182888) Contact Form: Filter Forge does not open Date: Fri, 23 Oct 2009 18:43:16 -0400 I do not have those or any program like those on my workstation... Any other options? -Eric" So I guess everything has to happen here in the forum anyway? What is next for me to try? |
| Posted: October 26, 2009 4:17 am | ||||
Posts: 3505 |
Please go to Start > Settings > Control Panel > System > Advanced > Permormance settings > Data execution prevention and add 'Filter Forge.exe' as an exception.
| Posted: October 26, 2009 8:07 am | ||||
| Eric MacArthur |
I did as you said then I restarted as Windows told me and it still doesn't work. |
| Posted: October 26, 2009 10:08 am | ||||
Posts: 3505 |
Hmm... we're running out of possible reasons. Do you have a debugger installed? Filter Forge won't start if a debugger is running.
| Posted: October 27, 2009 4:40 am | ||||
| Eric MacArthur |
No debugger
| Posted: October 27, 2009 4:43 am | ||||
Posts: 3505 |
One more question: please explain what you mean by 'will not run': the process starts but no GUI shows up? Please check in Task Manager if you have Filter Forge in the list of processes.
| Posted: October 27, 2009 8:18 am | ||||
| Eric MacArthur |
It does not show up in task manager.
| Posted: October 30, 2009 4:43 am | ||||
Posts: 3505 |
Does Filter Forge generate an error log? Please search your temp folder for a 'Filter Forge-SSE2.log' file.
(Note that you may have the log after successful runs in the safe mode. Please erase the temp folder, try to run Filter Forge and search for a log file then.) |
| Posted: October 30, 2009 9:36 am | ||||
| Eric MacArthur |
Here are the only Filter Forge anythings on my computer
| Posted: October 31, 2009 3:04 pm | ||||
Posts: 3505 |
Eric, could you please post two screenshots:
1) the Startup tab of your System configuration utility (Start > Run > msconfig); 2) the Processes tab of your Task Manager right after a fresh boot. Something on your computer prevents Filter Forge from starting, and this thing should run at startup. |
| Posted: November 2, 2009 5:02 am | ||||
| Eric MacArthur |
Thank you for not giving up on me
| Posted: November 2, 2009 6:01 pm | ||||
Posts: 3505 |
Eric, please disable ObjectDock, reboot and try to run Filter Forge.
| Posted: November 3, 2009 6:02 am | ||||
| Eric MacArthur |
That did not work. I disabled ObjectDock then rebooted (it went away from msconfig as it should) and no go. Then I reinstalled FF and still no go.
| Posted: November 4, 2009 2:56 am | ||||
Posts: 3505 |
I will ask the developers if they could suggest something else to help you...
| Posted: November 4, 2009 7:28 am | ||||
| Eric MacArthur |
FF 2.0beta also does not open...
When will I be hearing from someone? |
| Posted: November 8, 2009 4:57 am | ||||
Posts: 3505 |
Please search your computer for a file named RarExtLoader.exe.
If you find it, this may be the reason. It's a part of WinRAR, you will need to either delete WinRAR or disable shell integration: WinRAR > Options > Settings > Integration > disable shell integration. |
| Posted: November 19, 2009 7:55 am | ||||
| Eric MacArthur |
I use 7zip...
| Posted: November 22, 2009 3:13 am | ||||
| Eric MacArthur |
I tried uninstalling 7zip and disabling Color Eyes Pro to see if it would help and it did not...
| Posted: November 25, 2009 5:07 am | ||||
| Eric MacArthur |
I disabled everything in msconfig startup and restarted and it still won't start.
| Posted: November 25, 2009 5:17 am | ||||
Yannek
Posts: 5 |
I have exactly the same problem and I have allready tried everything I could think of with no success.
I am running Windows 7 64bit, Radeon 4850. Filter Forge used to work fine on my system but now it's dead. I guess it was some kind of update or maybe graphics driver/directx related installation. Will there be any solution to that problem ever? |
| Posted: January 31, 2010 6:08 pm | ||||
Yannek
Posts: 5 |
FilterForge 2 is almost out but there is no point of buying it if it won't work. Did anyone managed to solve this problem? Eric? GMM?
| Posted: March 10, 2010 2:13 pm | ||||
Posts: 3505 |
Yannek, we're unable to reproduce this. All versions of Filter Forge run fine on our Win7 machines.
| Posted: March 11, 2010 3:09 am | ||||
guys, try downloading FF again. i've had it happen with downloading any software, not just FF, where you get a partial download and it will even sometimes start the install and you think it's installed and it's not. the first check would be to look at the file size of the download. if it doesnt match up with what the FF website says it shld be, then you've got a bum download. uninstall everything, if it will and download the file again, paying attention to the file size.
also, make sure which version you're talking about here. in version 1.xxx the current version is 1.019. if you dont have that FF may not work and you certainly wont be able to download filters. if you're talking about version 2.xxx, the beta version, if you dont have the latest version there, i think it's 1.003, it wont work either and will give you a message telling you you have to update it. in that case, download the new ver 2.xxx version and install it directly over your other ver 2.xxx version. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: March 12, 2010 9:23 pm | ||||
136 unregistered users.
