Source: 50% grey from Assemble HLS.
A threashold setting of 50 results in black. Now type in 49.999. It will then round up to 50.00 but the result will be white. I understand this as "you can enter three decimals places of precision but we'll only display two of them". That's a bit confusing.
Also IMO a 50 threashold of 50% grey should equal 50% grey.
byRo
an Englishman in Brazil
I can see your reasoning but, to me anyway, the output can only be black or white and never anything else.
Agreed, (one of) the strong point(s) of FF is the "you-can't-do-anything-wrong" user interface. If the control shows one value but operates on another then that just ain`t right.
However, I think you've turned up a very, very special case in which one thousandth of one percent does make a whole lot of difference.
I'm still lamenting that the contrast and gamma functions needs an irrational number parameter in order to execute their simplest exact transformation (multiply by 2; square (root)).smile:cry:
So, how many decimal places does FF respect in a control?
If I put in 30.1029995663981 (OK, 30.1023 smile:) ) for a square root in the Gamma control will this exact number be saved with the filter - or does it get truncated?
Rô
onyXMaster
Filter Forge, Inc.
The only place where truncation is taking place is UI. So if UI will pass the untruncated value down, you'll get full 64-bit double precision floating point values both in the rendering pipeline and in the filter XML representation. So the only place to "fix" is the UI display limit.
onyXMaster
Filter Forge, Inc.
Just as a sidenote -- if the "full precision" UI is implemented (I'll leave the decision on possibility of this to Vladimir), you won't need irrational numbers anyway, just pop up your calculator, calculate your square root of two, PI or whatever and then just paste, I really don't think you need 80-bit precision the FPU is capable of (also 80-bit precision will get rounded to 64-bit very soon when rendering) smile:)
onyXMaster
Filter Forge, Inc.
And no, we're not going to implement a built-in calculator smile:)
byRo
Thanks for the reply, onyxMaster.
While jiggling a slider, I wouldn't want any decimal places at all - just when entering a number.
smile:cry: smile:D smile:D
Rô
What if the slider ranges from, say, 0 to 2?
Exactly, assuming that you replace "black" or "white" with "Low Color" and "High Color".
Agreed. We'll look into it.
I think we should be able to choose what color 50% grey becomes at 50 threashold.
Zev, in the simplest case (when the Smooth parameter is set to zero) Threshold is basically a conditional operator -- it is either True or False, and there's no middle.
But the Smooth parameter can provide that "middle" area -- for example if you want the 50% threashold of 50% grey to be equal 50% grey, set the Smooth parameter to a very small non-zero value, like 0.0001.
If you want something different from the colors that Threshold provides, plug it into Elevation Gradient and use a 3-Color Gradient to provide that particular color.
33,857 Registered Users
+44 new in year!
101 unregistered users.
