GulfRacer
Hi,
I use Adobe Photoshop Elements 7 and was working with a 400x336 image. Filter Forge give a proper preview, however when I actually apply a filter and return to Photoshop the filter effect is offset about 20 pixels to the left. This does not happen when I use it standalone so it seems to be an issue with the plugin and Elements. I have had this happen on the few different filters I have tried.
Any help is appreciated.
Did you figure this out? I don't use PS Elements so I can't help you on that one.. smile:)
GulfRacer, PSE 7 is not an officially supported host (yet). However, we will surely look into this when adding support for PSE 7.
GulfRacer
That's not what your host application page states:
http://www.filterforge.com/download/hosts.html
Adobe Photoshop Elements 2.0, 3.0, 4.0, 5.0, 6.0 and 7.0
So, any chance of this being fixed?
GulfRacer, obviously on August 10 PSE 7 was an unsupported host.
We're unable to reproduce the problem. Please report your Windows version and give detailed step-by-step instructions on what you are doing after you start PSE. Screenshots would be handy as well.
GulfRacer
This issue seems to manifest itself in various ways. My computer was running Vista when I first mentioned this issue but now I am running Windows 7.0, cleanly installed on a brand new hard drive and problems are the same as before. I have had no other problems with any other software I have.
Adobe Photoshop Elements Language Version: 7.0 (7.0 (20080916.r.508356))
Operating System: Windows Vista
Version: 6.1
System architecture: Intel CPU Family:6, Model:15, Stepping:11 with MMX, SSE Integer, SSE FP
Physical processor count: 2
Processor speed: 3000 MHz
Built-in memory: 2815 MB
Free memory: 899 MB
Memory available to Photoshop: 1652 MB
Memory used by Photoshop: 55 %
Image cache levels: 6
original image (435x360)
select entire image
The Filter Forge preview filter using the Craters2 filter. Not sure what part of the original image is actually being previewed here.
The End Result.
Changed the image size to 320x320 and used the Titanic Filter
At least now the preview works
However...
It may be worth mentioning that Filter Forge functions fine for me when used standalone.
