GMU
Posts: 2 |
| Posted: May 20, 2009 1:51 pm | ||||
Posts: 3505 |
What PSP version do you use?
For now, you can use Filter Forge in the stand-alone mode. |
| Posted: May 21, 2009 4:38 am | ||||
GMU
Posts: 2 |
Hi., I use the PSPX2 Ultimate and My Pc Windows Vista HOME PREMIUM 64 bits - Procesador i7., but the Filter Forge dont Work in my PSP and don´t work in stand Alone Mode
| Posted: May 31, 2009 7:26 am | ||||
Good to know.....I'm buying a new computer with an i7....and I "was" going purchase 64-bit Vista over XP Pro for the increase in graphics performance.....so it now looks like I'm back to XP Pro in order to run FF..... Question.....I know that FF is not able to utilize 64-bit yet.....but will it make any "performance" difference running FF on either 32 or 64-bit XP Pro??? My new machine will be able to boot multiple OS.....just wanted to know...... Steve
| Posted: May 31, 2009 12:03 pm | ||||
hillmh
Posts: 2 |
I have no problems running FF stand alone under Vista 64-bit Enterprise so please do not give up yet! FF also works great in PS CS4...
Problems of running under 64-bit can be very dificult to nail down.They can vary from need to update video drivers to changing install directory location. Vista is very protective off its enviroment. Some programs will just not run in the protected program areas. It is often necessary to install outside these areas. Do not assume that the install default areas are the right ones for you system.Try installing off root c:\ - after having done a backup so you can easily roll back should any problem occour. Rember when installing software ensure you install as administrator to ensure a correct install. With graphics programs and some filters it is often necessary to turn off Data Execution Prevention (DEP)for a particular program to run.For more info see http://www.vistax64.com/tutorials/120...sable.html. |
| Posted: June 5, 2009 9:46 am | ||||
