Tsu Dho Nimh
Posts: 190 |
With some filters, such as the barbed wire and lace filters, I am getting red fringing around what should be a black image. It shows up late in the process, and persists when I save the image.
Is this: 1 - Inherent in the way the filters are creating the images 2 - Because I'm using VMWare and Win2000 under Linux? 3 - Because my graphics card sucks? |
| Posted: March 16, 2009 3:53 pm | ||||
KGtheway2B
1 probably
2 maybe 3 not a chance (unless it's simply displaying the picture wrong) Which filters exactly- any links/example pics? |
| Posted: March 16, 2009 7:33 pm | ||||
Tsu Dho Nimh
Posts: 190 |
So far, seen it on these. I'm using them to make decorative braid for clothing, black or shades of black/grey on transparent.
http://www.filterforge.com/filters/5113.html (ribbons and wires) http://www.filterforge.com/filters/4050.html (chain or scroll) My workaround is to convert them to greyscale, but I lose some of the richness and shine. |
| Posted: March 17, 2009 5:20 pm | ||||
KGtheway2B
Ok so I put this onto a black background. (I'm assuming this is analogous to what you're doing?) Take a look below. I don't see any red haze, but if you still see it then it's probably your graphics card/monitor.
There's nothing out of the ordinary in the filter, so It doesn't look like it's an issue yet. |
| Posted: March 18, 2009 12:45 am | ||||
Tsu Dho Nimh
Posts: 190 |
It's a problem when I have dark components and a transparent background, such as this black filagree pattern. I forgot to write down which filter I was using for this, but the fringing happens late in the rendering, which makes me think it's a sharpen or blur.
| Posted: March 20, 2009 6:38 am | ||||
| Apples |
Maybe it has something to do with the set alpha component, the source color is red by default. So you can have a red shape onto a transparent background.
Or maybe it has something to do with the color on the first layer of the multiblend component with a transparent background input. Not sure if I'm thinking in the right direction here though. May The Forge Be With You |
| Posted: March 20, 2009 6:55 am | ||||
is this a surface type filter or a simple? if it's a surface type, try changing the surface color to white.
also, what happens if anti-aliasing is turned off? If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: March 20, 2009 7:48 am | ||||
Tsu Dho Nimh
Posts: 190 |
Give the man a !!!!! Turning off anti-aliasing gets rid of the fringes.
Thank you! |
| Posted: March 21, 2009 12:06 pm | ||||
interesting.
so, is this a surface type filter or a simple? and when's the last time you updated your video card drivers? If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: March 22, 2009 2:20 am | ||||
Tsu Dho Nimh
Posts: 190 |
How do you tell if it's surface or simple? (noob, I'm just a noob) And the drivers were updated in October, but because I'm running FF on Windows 2000 through a VMWare session on Linux ... that might not make a difference. |
| Posted: March 23, 2009 8:59 pm | ||||
in the main GUI, on the left where the presets and controls are, just above there there are either three or four tabs. if three they will say 'presets', 'settings' and 'about'. if four they will say 'presets', 'settings', 'lighting' and 'about'. if it has the four it's a surface type. if it only has three then it's a simple.
win 2k on linux thru vmware... now that's about as strange as it gets. no clue how that might affect your vid card. but, if when you turn off the anti-aliasing the fringe goes away, i would ask what type of machine are you running all this on and what type of video card and are you running directx 9.0c or some earlier version? and is your video card compatible with the new shader technology and such? If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: March 24, 2009 8:52 am | ||||
Tsu Dho Nimh
Posts: 190 |
It's pretty strange, but the alternatives would be running Windows
or not using FF at all
The VMware virtual machine does not take full advantage of the video card's ability - that's well known. It's getting better with each release of the client, but there are glitches with some of the advanced capabilities. |
| Posted: March 25, 2009 9:42 am | ||||
i think that's your answer right there. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: March 25, 2009 7:27 pm | ||||
18 unregistered users.
