i dont really know if this is a bug or a feature. you can plug control components into the green switches just fine and they'll work as normal. you can plug both intsliders and sliders in and no problem. however, if you use the curve ops switch and try to plug a slider into it you get the red exclamation point marker and if you plug an intslider into a curve ops switch it will only allow a setting of '1' and will not slide any further.
again, maybe there is a good reason for this, so i dont really know if it's a bug. just seemed a bit odd though.
craig
Yes, I agree this is a bit odd. This is a side effect of our current component architechture.
33,857 Registered Users
+44 new in year!
