hpgraphics117
hpgraphics117
After downloading and installing the trial of FF, I could not open FlexiSign or Photoshop without getting a ton of error messages. I deleted FF and I still get one error message:
This application has failed to start because dbghelp-xfw.dll was not found. Re-installing the application may fix this problem.
I click OK and the program still starts, but how can I get FF and my other programs to run peacefully?
That's weird. I've forwarded this to the programmers.
Also, could you please post screenshots or exact texts of all the error messages you're getting?
hpgraphics117
hpgraphics117
This is the error I know get after I uninstalled FF. I would have to reinstall to get the other error messages.
Did you delete FF manually by deleting it from Program Files, or via the uninstaller (Start > Control panel > Add/Remove programs)? Also, did you copy the FF plugin into Photoshop folder manually?
hpgraphics117
hpgraphics117
I'm pretty sure I used the uninstaller, though I may be wrong. I did not copy the plugin manually. It worked in Photoshop right away once it was installed.
20 unregistered users.
