| Cerberus |
unfortunatly for me, FF refuses to start. i messed around with it for a few hours, did some stuff, closed opened and closed FF again a few times, and now it won't start anymore. neither will the plugin work. here's a screenshot of what's going on-->
http://s10.photobucket.com/albums/a11...ed-2-6.jpg |
| Posted: November 5, 2008 10:43 am | ||
Have you tried running it as standalone (so close Photoshop and run the FF exe)?
| Posted: November 5, 2008 11:08 am | ||
also, you'll faster support, generally, if you use the contact FF form here on the site. the admins dont always check the forums each day, but they do check their email.
| Posted: November 5, 2008 12:53 pm | ||
| Cerberus |
Both the standalone and the plugin refuse to start. only the plugin gives an error message.
also, i've already sent them a message about it^_^ i thought i might as well try here while i was at it. i'm actualy quite sad about this whole thing. i was just getting into FF(6 1/2 hour straight long session). now i'm having all sorts of ideas that i won't be able to figure out until this whole thing blows over. |
| Posted: November 5, 2008 5:26 pm | ||
I would try reinstalling FF. Might be a corrupted file issue.
| Posted: November 6, 2008 8:36 am | ||
Yeah.....sounds like a corrupted install.....
Try turning off your antivirus during the install.....some AVs don't like FF's x86 files.....and can block, move, or delete them during install without you knowing it...... Steve
| Posted: November 6, 2008 8:47 am | ||
| Cerberus |
thanks evryone^_^ after re-installing it a few times, it finaly worked. i'm going to look into why it was doing what it was, and why it took so many fresh installs to fix.
| Posted: November 6, 2008 11:19 am | ||
20 unregistered users.
