I've encountered a rather strange bug - the refraction component seems to modify the precision of the subtree somehow (or the cache of the last component, dunno). See the attached filter - here the refractions output is not connected to anything at all, yet just hooking up its height input will affect other branches of the height source output.
Open the filter and try to disconnect/connect the refraction height input and notice how the brightness/contrast and blend output changes.. smile:?:
Edit:
Further investigation revealed that this happens no matter what you connect to the refraction input, down to the blur. So it seems to relate to the bitmap based blur source..
btw.. this bug is also present with the height input in the Surface Result.
strange bug.ffxml
This image shows what happens - the settings are exactly the same, only difference is the refraction height connection (note that the contrast isn't 100, its a rounding error in the display):
Weird indeed, especially since the Refraction isn't connected to the Result.
Could this be somehow related to the fact that Refraction samples its input tree with 3 times the amount of samples?
onyXMaster
Filter Forge, Inc.
Indeed, the Refraction and Result (Surface mode) "Height" inputs forces double-precision, along with changing the default bitmap sampling algorithm on all bitmap-based components on the attached subtree.
I am not sure of the reason behind the observed effect though, since while the extreme contrast adjustments tend to stress the precision-dependent errors, it seems strange that the switch to a higher precision actually increases percieved error.
In any case, thank you for pointing out and isolating the issue, we'll look into it.
Very interesting. We're looking into this.
18 unregistered users.
