i just noticed on this filter: http://www.filterforge.com/filters/5432.html that it isnt really an effect filter. it's a texture. however, it's listed in the effect filters. the reason is, it has an image component within it. however, that component isnt hooked up. it's just there. and that got me to wondering how many other filters might fit this same situation.
so, a suggestion on this, change your criteria for effect versus surface to ONLY include components that are actually in the subtree back from the result component. otherwise, we're going to have a very screwed up library in places.
(though, it is kind of an interesting trick to hide a surface/texture filter out of sight of the texture sellers smile;) ).
Yup, that definitely looks like a bug. Interesting trick nonetheless! smile;)
It's not a bug, it's a feature smile:)
Effect filters are determined by the presence of the Image component. If the author submits an update without this component, the filter will fall into the correct category.
Look inside the filter and you'll see that the image component isn't even connected to the Filter Tree, it just sits there on an orphaned branch. So it smells kind of like a bug since the filter tree that is actually used does not have an image component, and thus the filter should be categorized as a 'texture'.
Looks like the criteria should actually be:
Effect filters are determined by the presence of the Image component on the active filter tree.
yup, what dilla said. and i do know that this really is the author's responsibility in prime, but, it's YOUR library, too smile;)
the thing is, if i went looking for a 'dragon skin' filter, i'd go looking in texture filters, not effect filters. so, with a touch of programming, at least some of this could be addressed when an author goofs and leaves something in where it shldnt be. and heck, i sometimes leave orphaned routines in just to give someone else a look at other possibilities, but i wouldnt want them placed in the wrong spot because of it.
18 unregistered users.
