i dont know about the rest of you, but i havent had an FF crash in weeks now. i also did a control-alt-delete tonight and was looking at the performance tab and i couldnt find the memory leak with FF open.
so, to the FF team, did you fix something? sure seems like it and if so, thanks! If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: September 1, 2008 8:50 pm | ||||||
Unfortunately, the "resource leak" problem is still with us.....
![]() Steve
| Posted: September 1, 2008 9:50 pm | ||||||
Had one yesterday that took down a large photoshop session, nothing lost, but just reopening the files for that session took about 20 mins..
| Posted: September 2, 2008 2:33 am | ||||||
That doesn't sound good.....
I've trained myself to immediately save, shutdown, and restart at the first sign of any glitching or delayed responses.....which has successfully helped me to avoid crashes and loss of any work.....
As an extra precaution, I religeously backup the "My Filters" folder to a location outside of the FF folder.....especially after completing work that can not be easily be replicated..... Steve
| Posted: September 2, 2008 1:16 pm | ||||||
Beliria
Um I managed a double FF crash, followed by AOL crashing while filing the crash report lol!
Must have been a triple crash run.. Nothing wrong with a little insanity ;)
| Posted: September 2, 2008 4:21 pm | ||||||
| jffe |
I still get those fatal errors occasionally, and it's 50/50 to whether or not it erases the filter I was working on (which by the way, if it can crash and erase the filter to 0kb, certainly it could be altered to save the filter exactly as it is instead then crash, Sony does last save recovers with it's audio apps, and has auto-save every 5 mins or yay many changes, and it seems like any app could have that feature if they really put the effort into coding it in place of the lose-everything-crash ha-ha). Overall, FF's been running almost as stable as always, since I got that defective ram replaced it sure hasn't crashed any more than it did on a singlecore anyways.
jffe Filter Forger |
| Posted: September 2, 2008 4:56 pm | ||||||
nothing changed for me - some days it doesn't happen the next days it happen regularly
| Posted: September 4, 2008 4:05 am | ||||||
Yeah, that "Bastard Bug" (aka - Resource Leak) screws with your OS and affects other programs that are running..... I don't think it's a "resource leak" per se......it's more like a "Resource Hog".....gobbling and bunging things up in your OS..... I wish FF would just shell out some Rubels, draknars, quatloos (whatever Russian currency is) for some M$ Support and get rid of it once and for all....instead of trying to do more third-party patches!!! ![]() Steve
| Posted: September 4, 2008 8:46 am | ||||||
Beliria
Well I know I cant run Second life and FF at the same time but that might be cause I only have 1 gig ram, prob if I had dual core or more it might be better. Mind I did freak FF out yesterday was taking ages to open as the paint shop plug-in and I noticed it said hit esc to stop the plug-in, so I did. Then I managed to get 3 bug reports in a row from FF cause I did that. Had to restart paint shop too. I so wont be hitting esc again when FF is running slow for some reason Nothing wrong with a little insanity ;)
| Posted: September 4, 2008 8:57 am | ||||||
I'm not quite sure if that matters or not.....Carl has a good machine and has the problems.....but Dilla has a good machine as well and doesn't get them.....so I don't know..... A multi-core machine with alot of RAM is certainly going to run FF much faster.....it's specifically geared to run best on at least a dual-core machine..... I would suggest frequent saves, shutdowns, and restarts of FF to avoid it......works for me.....
| Posted: September 4, 2008 9:06 am | ||||||
Crashed again
.. this time it switched to demo mode while running, then it popped up the crash dialog and when clicking the save report thingie it all disappeared, leaving the "Filter Forge is running" plugin wrapper active so I couldn't get back into Photoshop - how about letting this plugin thing frequenty check if Filter Forge is running and if its crashed then abort. This way you don't have to kill PS and loose the complete session..
| Posted: September 11, 2008 9:04 am | ||||||
Miavir
I can confirm that Second Life and FF work together under 2 Gigs Ram and a Dual Core Processor. Mind you , the moment I start a filter rendering, SL goes to slideshow mode, but it DOES work, and I do that quite often. Now what I'd like to know is why SL just doesn't like TGA's rendered by FF. If I open the same TGA with Gimp, and do nothing to it, just resave, SL loads it fine. In ancient Egypt, Cats used to be revered as Gods.
Cats have never forgotten this. And rightly so. |
| Posted: September 12, 2008 8:09 am | ||||||
Beliria
okay will add a new computer to my wish list
| Posted: September 12, 2008 8:31 am | ||||||
Beliria
I had that issue with png format stuff after I got photoshop7, I ended up reinstalling paintshop pro and it worked fine again. Nothing wrong with a little insanity ;)
| Posted: September 12, 2008 8:32 am | ||||||
Miavir
Purrhaps I should be more specific: I CAN load TGA's rendered by FForge into SL, but they always come up as totally transparent. If I load the same file into GIMP, and write again with no changes made, SL now shows the proper Image when I upload it.
| Posted: September 15, 2008 6:20 am | ||||||
I've got my hopes on this finally remedying it!!!
| Posted: September 15, 2008 12:25 pm | ||||||
gholmes1936
Posts: 14 |
I've had three separate crashes today. I have used FF 2 several times with no problem. I have no idea which end is up now.
Process: Filter Forge [7808] Path: /Applications/Filter Forge 2/Filter Forge.app/Contents/MacOS/Filter Forge Identifier: com.FilterForge.FilterForge2 Version: ??? (2.0) Code Type: X86 (Native) Parent Process: launchd [123] Date/Time: 2010-11-07 12:33:45.119 -0600 OS Version: Mac OS X 10.6.4 (10F569) Report Version: 6 Interval Since Last Report: 263915 sec Crashes Since Last Report: 5 Per-App Interval Since Last Report: 37610 sec Per-App Crashes Since Last Report: 2 Anonymous UUID: 82EE37C1-18EF-45B4-BB26-82E5A2B08200 Exception Type: EXC_CRASH (SIGABRT) Exception Codes: 0x0000000000000000, 0x0000000000000000 Crashed Thread: 9 Application Specific Information: abort() called Thread 0: Dispatch queue: com.apple.main-thread 0 libSystem.B.dylib 0x968101d2 swtch_pri + 10 1 libSystem.B.dylib 0x968863dd sched_yield + 18 2 com.FilterForge.FilterForge2 0x0083a8a1 std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 2771 3 com.FilterForge.FilterForge2 0x00839315 std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string<char const*>(char const*, char const*, std::allocator<char> const&) + 541 4 com.FilterForge.FilterForge2 0x005826a6 XFW::AutoObjectPtr<FFXLib::ComponentManager>::AutoObjectPtr() + 11840 5 com.FilterForge.FilterForge2 0x005827f8 XFW::AutoObjectPtr<FFXLib::ComponentManager>::AutoObjectPtr() + 12178 6 com.FilterForge.FilterForge2 0x000420bf XFW::Graphics::Bitmap<XFW::Graphics::Pixel<XFW::Graphics::ChannelTraits<(XFW::Graphics::ChannelInfo::Format)0>, XFW::Graphics::PixelDescriptor<(XFW::Graphics::PixelInfo::Class)3, (XFW::Graphics::PixelInfo::Class)2, (XFW::Graphics::PixelInfo::Class)1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1> > >::fetch_scanline(void const*, XFW::Graphics::BitmapInfo::PixelFormat, unsigned int, bool) + 5823 7 com.FilterForge.FilterForge2 0x0004220f XFW::Graphics::Bitmap<XFW::Graphics::Pixel<XFW::Graphics::ChannelTraits<(XFW::Graphics::ChannelInfo::Format)0>, XFW::Graphics::PixelDescriptor<(XFW::Graphics::PixelInfo::Class)3, (XFW::Graphics::PixelInfo::Class)2, (XFW::Graphics::PixelInfo::Class)1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1> > >::fetch_scanline(void const*, XFW::Graphics::BitmapInfo::PixelFormat, unsigned int, bool) + 6159 8 com.FilterForge.FilterForge2 0x0061d4e3 std::vector<Controls::ListBox::ListBoxItem, std::allocator<Controls::ListBox::ListBoxItem> >::push_back(Controls::ListBox::ListBoxItem const&) + 6717 9 com.FilterForge.FilterForge2 0x00043b2b XFW::Graphics::Bitmap<XFW::Graphics::Pixel<XFW::Graphics::ChannelTraits<(XFW::Graphics::ChannelInfo::Format)0>, XFW::Graphics::PixelDescriptor<(XFW::Graphics::PixelInfo::Class)3, (XFW::Graphics::PixelInfo::Class)2, (XFW::Graphics::PixelInfo::Class)1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1> > >::fetch_scanline(void const*, XFW::Graphics::BitmapInfo::PixelFormat, unsigned int, bool) + 12587 10 com.FilterForge.FilterForge2 0x006162cf Controls::Label::~Label() + 2333 11 com.FilterForge.FilterForge2 0x00619b19 Controls::Label::~Label() + 16743 12 com.FilterForge.FilterForge2 0x00619c04 Controls::Label::~Label() + 16978 13 com.FilterForge.FilterForge2 0x005e373a Controls::ColorPlanePanel::~ColorPlanePanel() + 46098 14 com.FilterForge.FilterForge2 0x0060f9b3 XFW::Events::EventInvokeAdapter<Controls::FilterPreview, Controls::TimerWrapper::TimerEventArgs const>::clone_object() const + 17817 15 com.FilterForge.FilterForge2 0x005da1ec Controls::ColorPlanePanel::~ColorPlanePanel() + 7876 16 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 17 com.FilterForge.FilterForge2 0x005dc8c0 Controls::ColorPlanePanel::~ColorPlanePanel() + 17816 18 com.apple.HIToolbox 0x94147f2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567 19 com.apple.HIToolbox 0x941471f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 20 com.apple.HIToolbox 0x941699bb SendEventToEventTarget + 52 21 com.apple.HIToolbox 0x9417b4db ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1257 22 com.apple.HIToolbox 0x94148380 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672 23 com.apple.HIToolbox 0x941471f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 24 com.apple.HIToolbox 0x941699bb SendEventToEventTarget + 52 25 com.FilterForge.FilterForge2 0x0060be22 XFW::Events::EventInvokeAdapter<Controls::FilterPreview, Controls::TimerWrapper::TimerEventArgs const>::clone_object() const + 2568 26 com.FilterForge.FilterForge2 0x00612130 Controls::FormProcessingTask::invoke(XFW::OS::Environment&) + 68 27 com.FilterForge.FilterForge2 0x00810e65 FFXLib::Checker3::~Checker3() + 1849 28 com.FilterForge.FilterForge2 0x00811012 FFXLib::Checker3::~Checker3() + 2278 29 com.FilterForge.FilterForge2 0x0060e0ea XFW::Events::EventInvokeAdapter<Controls::FilterPreview, Controls::TimerWrapper::TimerEventArgs const>::clone_object() const + 11472 30 com.FilterForge.FilterForge2 0x000466f5 XFW::Graphics::Bitmap<XFW::Graphics::Pixel<XFW::Graphics::ChannelTraits<(XFW::Graphics::ChannelInfo::Format)0>, XFW::Graphics::PixelDescriptor<(XFW::Graphics::PixelInfo::Class)3, (XFW::Graphics::PixelInfo::Class)2, (XFW::Graphics::PixelInfo::Class)1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1> > >::fetch_scanline(void const*, XFW::Graphics::BitmapInfo::PixelFormat, unsigned int, bool) + 23797 31 com.FilterForge.FilterForge2 0x0007e5a4 XFW::Events::EventInvokeAdapter<FFX::FileProcessingForm, Controls::CloseQueryEventArgs>::clone_object() const + 80170 32 com.FilterForge.FilterForge2 0x0007e790 XFW::Events::EventInvokeAdapter<FFX::FileProcessingForm, Controls::CloseQueryEventArgs>::clone_object() const + 80662 33 com.FilterForge.FilterForge2 0x005ce7f5 Controls::BitmapWrapperNotInitialized::BitmapWrapperNotInitialized(std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const&) + 1191 34 com.FilterForge.FilterForge2 0x005da1ec Controls::ColorPlanePanel::~ColorPlanePanel() + 7876 35 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 36 com.FilterForge.FilterForge2 0x005dc8c0 Controls::ColorPlanePanel::~ColorPlanePanel() + 17816 37 com.apple.HIToolbox 0x94147f2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567 38 com.apple.HIToolbox 0x941471f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 39 com.apple.HIToolbox 0x941699bb SendEventToEventTarget + 52 40 com.apple.HIToolbox 0x941b8e56 SendControlHit(HIView*, OpaqueEventRef*, short, unsigned long) + 296 41 com.apple.HIToolbox 0x941b8cd7 HIView::NotifyControlHit(OpaqueEventRef*, short, unsigned long) + 45 42 com.apple.HIToolbox 0x9421d6fb HIView::ClickInternal(CGPoint const&, unsigned long, void (*)(OpaqueControlRef*, short), OpaqueEventRef*, bool) + 245 43 com.apple.HIToolbox 0x9421ecb4 HIView::ClickSelf(OpaqueEventRef*) + 368 44 com.apple.HIToolbox 0x9415ac81 HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 2363 45 com.apple.HIToolbox 0x94147f2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567 46 com.apple.HIToolbox 0x941471f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 47 com.apple.HIToolbox 0x941699bb SendEventToEventTarget + 52 48 com.apple.HIToolbox 0x941b7d26 HIView::Click(OpaqueEventRef*) + 480 49 com.apple.HIToolbox 0x941b7af3 HandleClickAsHIView(OpaqueWindowPtr*, OpaqueEventRef*) + 151 50 com.apple.HIToolbox 0x941b63d0 HandleWindowClick(OpaqueWindowPtr*, Point, short, unsigned long, OpaqueEventRef*) + 491 51 com.apple.HIToolbox 0x941b5ed3 HandleMouseEvent(OpaqueEventHandlerCallRef*, OpaqueEventRef*) + 786 52 com.apple.HIToolbox 0x941b57de StandardWindowEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 93 53 com.apple.HIToolbox 0x94147f2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567 54 com.apple.HIToolbox 0x941471f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 55 com.apple.HIToolbox 0x941b4441 CallNextEventHandler + 95 56 com.FilterForge.FilterForge2 0x005e3e78 Controls::ColorPlanePanel::~ColorPlanePanel() + 47952 57 com.FilterForge.FilterForge2 0x0060f9b3 XFW::Events::EventInvokeAdapter<Controls::FilterPreview, Controls::TimerWrapper::TimerEventArgs const>::clone_object() const + 17817 58 com.FilterForge.FilterForge2 0x005da1ec Controls::ColorPlanePanel::~ColorPlanePanel() + 7876 59 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 60 com.FilterForge.FilterForge2 0x005dc8c0 Controls::ColorPlanePanel::~ColorPlanePanel() + 17816 61 com.apple.HIToolbox 0x94147f2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567 62 com.apple.HIToolbox 0x941471f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 63 com.apple.HIToolbox 0x941699bb SendEventToEventTarget + 52 64 com.apple.HIToolbox 0x9417b4db ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1257 65 com.apple.HIToolbox 0x94148380 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672 66 com.apple.HIToolbox 0x941471f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 67 com.apple.HIToolbox 0x941699bb SendEventToEventTarget + 52 68 com.FilterForge.FilterForge2 0x0060be22 XFW::Events::EventInvokeAdapter<Controls::FilterPreview, Controls::TimerWrapper::TimerEventArgs const>::clone_object() const + 2568 69 com.FilterForge.FilterForge2 0x00612130 Controls::FormProcessingTask::invoke(XFW::OS::Environment&) + 68 70 com.FilterForge.FilterForge2 0x00810e65 FFXLib::Checker3::~Checker3() + 1849 71 com.FilterForge.FilterForge2 0x00811012 FFXLib::Checker3::~Checker3() + 2278 72 com.FilterForge.FilterForge2 0x0060e0ea XFW::Events::EventInvokeAdapter<Controls::FilterPreview, Controls::TimerWrapper::TimerEventArgs const>::clone_object() const + 11472 73 com.FilterForge.FilterForge2 0x0006b824 XFW::Events::EventInvokeAdapter<FFX::FileProcessingForm, Controls::CloseQueryEventArgs>::clone_object() const + 2986 74 com.FilterForge.FilterForge2 0x00145c9c XFW::Events::EventInvokeAdapter<FFX::LightingSettingsPanel, Controls::KeyboardEventArgs const>::clone_object() const + 14758 75 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 76 com.FilterForge.FilterForge2 0x00832371 XFW::Helpers::CheckFailed::clone_object() const + 9381 77 com.FilterForge.FilterForge2 0x008364b0 XFW::Localization::LanguagesStorage::~LanguagesStorage() + 118 78 com.FilterForge.FilterForge2 0x00002746 0x1000 + 5958 Thread 1: Dispatch queue: com.apple.libdispatch-manager 0 libSystem.B.dylib 0x96836942 kevent + 10 1 libSystem.B.dylib 0x9683705c _dispatch_mgr_invoke + 215 2 libSystem.B.dylib 0x96836519 _dispatch_queue_invoke + 163 3 libSystem.B.dylib 0x968362be _dispatch_worker_thread2 + 240 4 libSystem.B.dylib 0x96835d41 _pthread_wqthread + 390 5 libSystem.B.dylib 0x96835b86 start_wqthread + 30 Thread 2: 0 libSystem.B.dylib 0x9681014e semaphore_timedwait_trap + 10 1 ...ple.CoreServices.CarbonCore 0x97fc315e MPWaitOnSemaphore + 125 2 com.FilterForge.FilterForge2 0x0083a72f std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 2401 3 com.FilterForge.FilterForge2 0x0081150a FFXLib::Checker3::~Checker3() + 3550 4 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 5 com.FilterForge.FilterForge2 0x0083aa24 std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 3158 6 libSystem.B.dylib 0x9683d81d _pthread_start + 345 7 libSystem.B.dylib 0x9683d6a2 thread_start + 34 Thread 3: 0 libSystem.B.dylib 0x968171ac szone_free_definite_size + 929 1 libSystem.B.dylib 0x96816ba8 free + 244 2 com.FilterForge.FilterForge2 0x00093a32 std::_Rb_tree<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item>, std::_Select1st<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> >, std::less<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> > >::destroy_node(std::_Rb_tree_node<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> >*) + 80 3 com.FilterForge.FilterForge2 0x00093a69 std::_Rb_tree<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item>, std::_Select1st<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> >, std::less<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> > >::_M_erase(std::_Rb_tree_node<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> >*) + 47 4 com.FilterForge.FilterForge2 0x00093a96 std::_Rb_tree<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item>, std::_Select1st<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> >, std::less<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> > >::~_Rb_tree() + 30 5 com.FilterForge.FilterForge2 0x00093ad2 std::auto_ptr<std::map<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, FFXLib::Serialization::Item, std::less<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> > > >::~auto_ptr() + 24 6 com.FilterForge.FilterForge2 0x0009385b FFXLib::Serialization::Item::~Item() + 37 7 com.FilterForge.FilterForge2 0x0009390b std::_List_base<FFXLib::Serialization::Item, std::allocator<FFXLib::Serialization::Item> >::_M_clear() + 47 8 com.FilterForge.FilterForge2 0x00093955 std::_List_base<FFXLib::Serialization::Item, std::allocator<FFXLib::Serialization::Item> >::~_List_base() + 23 9 com.FilterForge.FilterForge2 0x00093990 std::auto_ptr<std::list<FFXLib::Serialization::Item, std::allocator<FFXLib::Serialization::Item> > >::~auto_ptr() + 24 10 com.FilterForge.FilterForge2 0x00093877 FFXLib::Serialization::Item::~Item() + 65 11 com.FilterForge.FilterForge2 0x000939be std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item>::~pair() + 26 12 com.FilterForge.FilterForge2 0x00093a0e std::_Rb_tree<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item>, std::_Select1st<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> >, std::less<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> > >::destroy_node(std::_Rb_tree_node<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> >*) + 44 13 com.FilterForge.FilterForge2 0x00093a69 std::_Rb_tree<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item>, std::_Select1st<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> >, std::less<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> > >::_M_erase(std::_Rb_tree_node<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> >*) + 47 14 com.FilterForge.FilterForge2 0x00093a5a std::_Rb_tree<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item>, std::_Select1st<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> >, std::less<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> > >::_M_erase(std::_Rb_tree_node<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> >*) + 32 15 com.FilterForge.FilterForge2 0x00093a96 std::_Rb_tree<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item>, std::_Select1st<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> >, std::less<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> > >::~_Rb_tree() + 30 16 com.FilterForge.FilterForge2 0x00093ad2 std::auto_ptr<std::map<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, FFXLib::Serialization::Item, std::less<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, FFXLib::Serialization::Item> > > >::~auto_ptr() + 24 17 com.FilterForge.FilterForge2 0x0009385b FFXLib::Serialization::Item::~Item() + 37 18 com.FilterForge.FilterForge2 0x000938c8 std::auto_ptr<FFXLib::Serialization::Item>::~auto_ptr() + 24 19 com.FilterForge.FilterForge2 0x00534a4c std::vector<FFXLib::RandomizePresetItem, std::allocator<FFXLib::RandomizePresetItem> >::push_back(FFXLib::RandomizePresetItem const&) + 54586 20 com.FilterForge.FilterForge2 0x0050246e FFXLib::DefaultCurve::~DefaultCurve() + 22670 21 com.FilterForge.FilterForge2 0x0050dd47 FFXLib::DefaultCurve::~DefaultCurve() + 69991 22 com.FilterForge.FilterForge2 0x0051061c FFXLib::DefaultCurve::~DefaultCurve() + 80444 23 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 24 com.FilterForge.FilterForge2 0x00507db4 FFXLib::DefaultCurve::~DefaultCurve() + 45524 25 com.FilterForge.FilterForge2 0x00810e65 FFXLib::Checker3::~Checker3() + 1849 26 com.FilterForge.FilterForge2 0x008114f1 FFXLib::Checker3::~Checker3() + 3525 27 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 28 com.FilterForge.FilterForge2 0x0083aa24 std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 3158 29 libSystem.B.dylib 0x9683d81d _pthread_start + 345 30 libSystem.B.dylib 0x9683d6a2 thread_start + 34 Thread 4: 0 libSystem.B.dylib 0x9681014e semaphore_timedwait_trap + 10 1 ...ple.CoreServices.CarbonCore 0x97fc315e MPWaitOnSemaphore + 125 2 com.FilterForge.FilterForge2 0x0083a72f std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 2401 3 com.FilterForge.FilterForge2 0x0081150a FFXLib::Checker3::~Checker3() + 3550 4 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 5 com.FilterForge.FilterForge2 0x0083aa24 std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 3158 6 libSystem.B.dylib 0x9683d81d _pthread_start + 345 7 libSystem.B.dylib 0x9683d6a2 thread_start + 34 Thread 5: 0 libSystem.B.dylib 0x9681014e semaphore_timedwait_trap + 10 1 ...ple.CoreServices.CarbonCore 0x97fc315e MPWaitOnSemaphore + 125 2 com.FilterForge.FilterForge2 0x0083a72f std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 2401 3 com.FilterForge.FilterForge2 0x0081150a FFXLib::Checker3::~Checker3() + 3550 4 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 5 com.FilterForge.FilterForge2 0x0083aa24 std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 3158 6 libSystem.B.dylib 0x9683d81d _pthread_start + 345 7 libSystem.B.dylib 0x9683d6a2 thread_start + 34 Thread 6: 0 libSystem.B.dylib 0x9681014e semaphore_timedwait_trap + 10 1 ...ple.CoreServices.CarbonCore 0x97fc315e MPWaitOnSemaphore + 125 2 com.FilterForge.FilterForge2 0x0083a72f std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 2401 3 com.FilterForge.FilterForge2 0x0081150a FFXLib::Checker3::~Checker3() + 3550 4 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 5 com.FilterForge.FilterForge2 0x0083aa24 std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 3158 6 libSystem.B.dylib 0x9683d81d _pthread_start + 345 7 libSystem.B.dylib 0x9683d6a2 thread_start + 34 Thread 7: 0 libSystem.B.dylib 0x9681014e semaphore_timedwait_trap + 10 1 ...ple.CoreServices.CarbonCore 0x97fc315e MPWaitOnSemaphore + 125 2 com.FilterForge.FilterForge2 0x0083a72f std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 2401 3 com.FilterForge.FilterForge2 0x0081150a FFXLib::Checker3::~Checker3() + 3550 4 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 5 com.FilterForge.FilterForge2 0x0083aa24 std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 3158 6 libSystem.B.dylib 0x9683d81d _pthread_start + 345 7 libSystem.B.dylib 0x9683d6a2 thread_start + 34 Thread 8: 0 libSystem.B.dylib 0x9681014e semaphore_timedwait_trap + 10 1 ...ple.CoreServices.CarbonCore 0x97fc315e MPWaitOnSemaphore + 125 2 com.FilterForge.FilterForge2 0x0083a72f std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 2401 3 com.FilterForge.FilterForge2 0x0081150a FFXLib::Checker3::~Checker3() + 3550 4 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 5 com.FilterForge.FilterForge2 0x0083aa24 std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 3158 6 libSystem.B.dylib 0x9683d81d _pthread_start + 345 7 libSystem.B.dylib 0x9683d6a2 thread_start + 34 Thread 9 Crashed: 0 libSystem.B.dylib 0x9687d28e __semwait_signal_nocancel + 10 1 libSystem.B.dylib 0x9687d172 nanosleep$NOCANCEL$UNIX2003 + 166 2 libSystem.B.dylib 0x968f803a usleep$NOCANCEL$UNIX2003 + 61 3 libSystem.B.dylib 0x969196f0 abort + 105 4 libSystem.B.dylib 0x96895c9b _Unwind_Resume + 59 5 com.FilterForge.FilterForge2 0x005b4dd9 std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const XFW::Strings::replace_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >(std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const&, std::list<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::allocator<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > > const*, std::list<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::allocator<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > > const*) + 12783 6 com.FilterForge.FilterForge2 0x0030e1d3 Iex::EpermExc::~EpermExc() + 850739 7 com.FilterForge.FilterForge2 0x003196fe Iex::EpermExc::~EpermExc() + 897118 8 com.FilterForge.FilterForge2 0x0030e610 Iex::EpermExc::~EpermExc() + 851824 9 com.FilterForge.FilterForge2 0x0030a071 Iex::EpermExc::~EpermExc() + 834001 10 com.FilterForge.FilterForge2 0x0030daeb Iex::EpermExc::~EpermExc() + 848971 11 com.FilterForge.FilterForge2 0x0030e932 Iex::EpermExc::~EpermExc() + 852626 12 com.FilterForge.FilterForge2 0x0030a0e5 Iex::EpermExc::~EpermExc() + 834117 13 com.FilterForge.FilterForge2 0x005b78bc std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const XFW::Strings::replace_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >(std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const&, std::list<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::allocator<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > > const*, std::list<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::allocator<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > > const*) + 23762 14 com.FilterForge.FilterForge2 0x005c4a3a std::vector<double, std::allocator<double> >::reserve(unsigned long) + 1802 15 com.FilterForge.FilterForge2 0x00560028 std::map<std::pair<int const, int const>, FFXLib::LibraryStructure::Filter, std::less<std::pair<int const, int const> >, std::allocator<std::pair<std::pair<int const, int const> const, FFXLib::LibraryStructure::Filter> > >::operator[](std::pair<int const, int const> const&) + 4176 16 com.FilterForge.FilterForge2 0x0077ee39 void FFXLib::PercentileImplementation::StaticImplementation::percentile_int<false, false>(FFXLib::PercentileImplementation const&, FFXLib::RenderingBlock&) + 3015 17 com.FilterForge.FilterForge2 0x00560028 std::map<std::pair<int const, int const>, FFXLib::LibraryStructure::Filter, std::less<std::pair<int const, int const> >, std::allocator<std::pair<std::pair<int const, int const> const, FFXLib::LibraryStructure::Filter> > >::operator[](std::pair<int const, int const> const&) + 4176 18 com.FilterForge.FilterForge2 0x0077eda8 void FFXLib::PercentileImplementation::StaticImplementation::percentile_int<false, false>(FFXLib::PercentileImplementation const&, FFXLib::RenderingBlock&) + 2870 19 com.FilterForge.FilterForge2 0x00560028 std::map<std::pair<int const, int const>, FFXLib::LibraryStructure::Filter, std::less<std::pair<int const, int const> >, std::allocator<std::pair<std::pair<int const, int const> const, FFXLib::LibraryStructure::Filter> > >::operator[](std::pair<int const, int const> const&) + 4176 20 com.FilterForge.FilterForge2 0x0077eda8 void FFXLib::PercentileImplementation::StaticImplementation::percentile_int<false, false>(FFXLib::PercentileImplementation const&, FFXLib::RenderingBlock&) + 2870 21 com.FilterForge.FilterForge2 0x00560028 std::map<std::pair<int const, int const>, FFXLib::LibraryStructure::Filter, std::less<std::pair<int const, int const> >, std::allocator<std::pair<std::pair<int const, int const> const, FFXLib::LibraryStructure::Filter> > >::operator[](std::pair<int const, int const> const&) + 4176 22 com.FilterForge.FilterForge2 0x0077eda8 void FFXLib::PercentileImplementation::StaticImplementation::percentile_int<false, false>(FFXLib::PercentileImplementation const&, FFXLib::RenderingBlock&) + 2870 23 com.FilterForge.FilterForge2 0x00560028 std::map<std::pair<int const, int const>, FFXLib::LibraryStructure::Filter, std::less<std::pair<int const, int const> >, std::allocator<std::pair<std::pair<int const, int const> const, FFXLib::LibraryStructure::Filter> > >::operator[](std::pair<int const, int const> const&) + 4176 24 com.FilterForge.FilterForge2 0x0077eda8 void FFXLib::PercentileImplementation::StaticImplementation::percentile_int<false, false>(FFXLib::PercentileImplementation const&, FFXLib::RenderingBlock&) + 2870 25 com.FilterForge.FilterForge2 0x0055ff06 std::map<std::pair<int const, int const>, FFXLib::LibraryStructure::Filter, std::less<std::pair<int const, int const> >, std::allocator<std::pair<std::pair<int const, int const> const, FFXLib::LibraryStructure::Filter> > >::operator[](std::pair<int const, int const> const&) + 3886 26 com.FilterForge.FilterForge2 0x0055ff06 std::map<std::pair<int const, int const>, FFXLib::LibraryStructure::Filter, std::less<std::pair<int const, int const> >, std::allocator<std::pair<std::pair<int const, int const> const, FFXLib::LibraryStructure::Filter> > >::operator[](std::pair<int const, int const> const&) + 3886 27 com.FilterForge.FilterForge2 0x00592c62 FFXLib::ResultBitmapCache::~ResultBitmapCache() + 43550 28 com.FilterForge.FilterForge2 0x0057af04 bool FFXLib::Renderer::StaticImplementation::render_bitmap_first_pass<unsigned int, FFXLib::get_sample_basic, XFW::Graphics::Pixel<XFW::Graphics::ChannelTraits<(XFW::Graphics::ChannelInfo::Format)4>, XFW::Graphics::PixelDescriptor<(XFW::Graphics::PixelInfo::Class)1, (XFW::Graphics::PixelInfo::Class)2, (XFW::Graphics::PixelInfo::Class)3, (XFW::Graphics::PixelInfo::Class)13, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1> > >(FFXLib::get_sample_basic const&, XFW::Graphics::Point const&, XFW::Graphics::Bitmap<XFW::Graphics::Pixel<XFW::Graphics::ChannelTraits<(XFW::Graphics::ChannelInfo::Format)4>, XFW::Graphics::PixelDescriptor<(XFW::Graphics::PixelInfo::Class)1, (XFW::Graphics::PixelInfo::Class)2, (XFW::Graphics::PixelInfo::Class)3, (XFW::Graphics::PixelInfo::Class)13, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1, (XFW::Graphics::PixelInfo::Class)-1> > >&, FFXLib::DirtyBitmap&, unsigned int&) + 1016 29 com.FilterForge.FilterForge2 0x00571388 std::vector<FFXLib::Property::StringValue, std::allocator<FFXLib::Property::StringValue> >::operator=(std::vector<FFXLib::Property::StringValue, std::allocator<FFXLib::Property::StringValue> > const&) + 12250 30 com.FilterForge.FilterForge2 0x00571e45 std::vector<FFXLib::Property::StringValue, std::allocator<FFXLib::Property::StringValue> >::operator=(std::vector<FFXLib::Property::StringValue, std::allocator<FFXLib::Property::StringValue> > const&) + 14999 31 com.FilterForge.FilterForge2 0x005722a2 std::vector<FFXLib::Property::StringValue, std::allocator<FFXLib::Property::StringValue> >::operator=(std::vector<FFXLib::Property::StringValue, std::allocator<FFXLib::Property::StringValue> > const&) + 16116 32 com.FilterForge.FilterForge2 0x00583ead XFW::AutoObjectPtr<FFXLib::ComponentManager>::AutoObjectPtr() + 17991 33 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 34 com.FilterForge.FilterForge2 0x005840ca XFW::AutoObjectPtr<FFXLib::ComponentManager>::AutoObjectPtr() + 18532 35 com.FilterForge.FilterForge2 0x00810e65 FFXLib::Checker3::~Checker3() + 1849 36 com.FilterForge.FilterForge2 0x008114f1 FFXLib::Checker3::~Checker3() + 3525 37 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 38 com.FilterForge.FilterForge2 0x0083aa24 std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 3158 39 libSystem.B.dylib 0x9683d81d _pthread_start + 345 40 libSystem.B.dylib 0x9683d6a2 thread_start + 34 Thread 10: 0 libSystem.B.dylib 0x9681014e semaphore_timedwait_trap + 10 1 ...ple.CoreServices.CarbonCore 0x97fc315e MPWaitOnSemaphore + 125 2 com.FilterForge.FilterForge2 0x0083a72f std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 2401 3 com.FilterForge.FilterForge2 0x0081150a FFXLib::Checker3::~Checker3() + 3550 4 com.FilterForge.FilterForge2 0x00830e2c XFW::Helpers::CheckFailed::clone_object() const + 3936 5 com.FilterForge.FilterForge2 0x0083aa24 std::_Rb_tree<unsigned int, std::pair<unsigned int const, unsigned int>, std::_Select1st<std::pair<unsigned int const, unsigned int> >, std::less<unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> > >::insert_unique(std::pair<unsigned int const, unsigned int> const&) + 3158 6 libSystem.B.dylib 0x9683d81d _pthread_start + 345 7 libSystem.B.dylib 0x9683d6a2 thread_start + 34 Thread 9 crashed with X86 Thread State (32-bit): eax: 0x0000003c ebx: 0x9687d0d9 ecx: 0xb0d9996c edx: 0x9687d28e edi: 0xb0d99e48 esi: 0xb0d999c8 ebp: 0xb0d999a8 esp: 0xb0d9996c ss: 0x0000001f efl: 0x00000247 eip: 0x9687d28e cs: 0x00000007 ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037 cr2: 0xb0d96cfc Binary Images: 0x1000 - 0xb25fe7 +com.FilterForge.FilterForge2 ??? (2.0) <FEE32717-9B1C-45F0-80BD-A0E8F11F4A0F> /Applications/Filter Forge 2/Filter Forge.app/Contents/MacOS/Filter Forge 0x152a000 - 0x152bffb +com.cooliris.safariplugin Cooliris Plugin (1.11) <439BB2F5-0ED4-2BB3-8AF3-1BDFF7D2A85F> /Library/InputManagers/Cooliris/Cooliris.bundle/Contents/MacOS/Cooliris 0x152f000 - 0x15e4fe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib 0x179f5000 - 0x179f7ff7 com.apple.MLTEFile 3.2.0 (3.2.0) <71F70505-F986-B8E1-7C0D-278DF22742ED> /System/Library/CoreServices/MLTEFile.bundle/Contents/MacOS/MLTEFile 0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <A4F6ADCC-6448-37B4-ED6C-ABB2CD06F448> /usr/lib/dyld 0x90003000 - 0x90095fe3 com.apple.print.framework.PrintCore 6.2 (312.5) <7729B4D7-D661-D669-FA7E-510F93F685A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x900d4000 - 0x90105ff3 libTrueTypeScaler.dylib ??? (???) <7601D717-236D-8F4E-91F5-E69BB2920478> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib 0x9011a000 - 0x9011aff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib 0x9011b000 - 0x90151fff libtidy.A.dylib ??? (???) <DDFAB560-3883-A6A2-7BDD-D91730982B48> /usr/lib/libtidy.A.dylib 0x9015f000 - 0x901a5ff7 libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib 0x901a6000 - 0x901a6ff7 com.apple.Carbon 150 (152) <9252D5F2-462D-2C15-80F3-109644D6F704> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x901c0000 - 0x9039bff3 libType1Scaler.dylib ??? (???) <6FBA8250-3271-6ED4-052D-E27C2136E38F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib 0x9039c000 - 0x903a8ff7 libkxld.dylib ??? (???) <322A4B52-8305-3081-6B74-813C3A87A56D> /usr/lib/system/libkxld.dylib 0x903a9000 - 0x903b7fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib 0x903f7000 - 0x90405ff7 com.apple.opengl 1.6.9 (1.6.9) <4F06C166-00CF-5ACF-77E3-5A960A5E8AD3> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x90406000 - 0x90408ff7 libRadiance.dylib ??? (???) <AB06F616-E3EA-5966-029A-8AA44BBE5B28> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x90541000 - 0x90545ff7 libGIF.dylib ??? (???) <3ECD4D2C-40FE-E9A0-A2D2-E36D1C00D3A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x90546000 - 0x90589ff7 libGLU.dylib ??? (???) <2093A1FB-67BD-39E0-CDE5-A97A77BDDBCE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x905bf000 - 0x905bfff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x905c0000 - 0x905e1fe7 com.apple.opencl 12.1 (12.1) <DA2AC3FA-ED11-2D10-21E9-7BDF4778B228> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL 0x909c1000 - 0x90ac2fe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib 0x91b62000 - 0x91bc3fe7 com.apple.CoreText 3.1.0 (???) <1372DABE-F183-DD03-03C2-64B2464A4FD5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText 0x91bc4000 - 0x91e34ffb com.apple.Foundation 6.6.3 (751.29) <E77D3906-99F4-FEF4-FBB0-86FB3C94073E> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x91e35000 - 0x91feffe3 com.apple.ImageIO.framework 3.0.3 (3.0.3) <A93A514B-C1BF-21D0-FB03-CB775DE4FFAA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x91ff0000 - 0x91ff0ff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x91ff1000 - 0x92024ff7 com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x92161000 - 0x921f9fe7 edu.mit.Kerberos 6.5.10 (6.5.10) <8B83AFF3-C074-E47C-4BD0-4546EED0D1BC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x92265000 - 0x92266ff7 com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent 0x92267000 - 0x92342fe7 com.apple.DesktopServices 1.5.7 (1.5.7) <A69072AD-C47E-A00D-4A69-6E46A7FB2119> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x923bb000 - 0x923c6ff7 libCSync.A.dylib 543.50.0 (compatibility 64.0.0) <4FA0CE4A-BDE5-0E3D-37F0-03B41F0C2637> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib 0x9250a000 - 0x92547ff7 com.apple.SystemConfiguration 1.10.2 (1.10.2) <398BB007-41FD-1A30-26D8-CB86ED5E467E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x929ac000 - 0x929ccfe7 libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib 0x92a07000 - 0x92a23fe3 com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x92a26000 - 0x92a2aff7 libGFXShared.dylib ??? (???) <2D32BDBF-C941-93FD-E233-F03D28DB9E94> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x92a7c000 - 0x92abfff7 com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices 0x92ac0000 - 0x92b04fe7 com.apple.Metadata 10.6.3 (507.10) <630494FA-3BB3-EDD3-E10B-8DAAF4831E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x92b38000 - 0x92b5cff7 libJPEG.dylib ??? (???) <5CE96981-6B2A-D15B-4A17-E7BD329095B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x92b5d000 - 0x92b60ff7 libCoreVMClient.dylib ??? (???) <CA0BA8DC-0159-A808-A300-750358A6970C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x92ba3000 - 0x92ccffff com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) <F0D7256E-0914-8E77-E37B-9720430422AB> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x92cd0000 - 0x93038ff7 com.apple.QuartzCore 1.6.2 (227.22) <4288F0D2-0C87-F054-C372-8764B44DE024> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x932c2000 - 0x932c5ff7 libCGXType.A.dylib 543.50.0 (compatibility 64.0.0) <3B49AED9-0DBA-9D21-F9AC-8784363AD762> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib 0x933f3000 - 0x933f8ff7 com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x933f9000 - 0x9340efff com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x9340f000 - 0x93844ff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x93845000 - 0x93a3cfeb com.apple.JavaScriptCore 6533.18 (6533.18.1) <EE3897A8-E1C0-DE28-A631-4B0C32DF737B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x93a44000 - 0x93aedff7 com.apple.CFNetwork 454.9.8 (454.9. 0x93aee000 - 0x93b70ffb SecurityFoundation ??? (???) <3670AE8B-06DA-C447-EB14-79423DB9C474> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x93eea000 - 0x93eecff7 com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x93efd000 - 0x93f00ffb com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x93f01000 - 0x94010fe7 com.apple.WebKit 6533.18 (6533.18.1) <157D0DD9-F3CE-4339-858B-B0EFFAA3B008> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit 0x94011000 - 0x9413ffe7 com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x94140000 - 0x94464fef com.apple.HIToolbox 1.6.3 (???) <0A5F56E2-9AF3-728D-70AE-429522AEAD8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x9449e000 - 0x944b6ff7 com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x944d6000 - 0x944eafe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib 0x944eb000 - 0x94523ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <76C02F5C-98FD-BD64-B5FB-C698FB76EA25> /usr/lib/libcups.2.dylib 0x94524000 - 0x94f6fff7 com.apple.WebCore 6533.18 (6533.18.1) <B96BFDB8-3D11-E220-1148-206D8A176352> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore 0x95012000 - 0x95012ff7 com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x9503e000 - 0x95068ff7 com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut 0x9519f000 - 0x951faff7 com.apple.framework.IOKit 2.0 (???) <A013B850-6ECB-594A-CBD6-DB156B11871B> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x95200000 - 0x95200ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x95201000 - 0x95245ff3 com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI 0x95246000 - 0x9524cfff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x9524d000 - 0x9527eff7 libGLImage.dylib ??? (???) <9340012D-595A-6243-9C97-7D30D76D9D9E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x9527f000 - 0x95a6e557 com.apple.CoreGraphics 1.545.0 (???) <DCED8E1A-7504-C31A-B6EF-98BFF1A61060> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x95a70000 - 0x95a96fff com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x95a97000 - 0x95aa1ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x95aa2000 - 0x95aabff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x95aba000 - 0x95b03fe7 libTIFF.dylib ??? (???) <9CFF48CC-4852-4D06-17AC-3C947C824159> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x95b04000 - 0x95b04ff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x95b6a000 - 0x9644aff7 com.apple.AppKit 6.6.6 (1038.29) <6F28C335-6DC2-AE0E-B79A-F256DBD0BB45> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x964ab000 - 0x9659dff7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9. 0x96755000 - 0x967b9ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering 0x9680f000 - 0x969b5feb libSystem.B.dylib 125.2.0 (compatibility 1.0.0) <3441F338-2218-6D36-3F95-3A16FBF6713D> /usr/lib/libSystem.B.dylib 0x969b6000 - 0x96a51ff7 com.apple.ApplicationServices.ATS 275.11.1 (???) <5FF65EC7-F512-530A-7771-3DE240EE6E43> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x96a52000 - 0x96b2fff7 com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x96b7b000 - 0x96b96ff7 libPng.dylib ??? (???) <36A3D75E-5178-4358-7F02-444E276D61AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x96b9d000 - 0x96bbbff7 com.apple.CoreVideo 1.6.1 (45.4) <E0DF044D-BF31-42CE-B690-FD1FCE07E64A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x96eef000 - 0x96effff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib 0x96f00000 - 0x96f01ff7 com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <959DFFAE-A06B-7FF6-B713-B2076893EBBD> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x96f15000 - 0x96fbdffb com.apple.QD 3.35 (???) <B80B64BC-958B-DA9E-50F9-D7E8333CC5A2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x96fbe000 - 0x96fffff7 libRIP.A.dylib 543.50.0 (compatibility 64.0.0) <8BAE1FC1-A478-F151-17C7-2D5DE470AC4F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib 0x97074000 - 0x971eefe3 com.apple.CoreFoundation 6.6.3 (550.29) <00373783-3744-F47D-2191-BEEA658F0C3D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x971ef000 - 0x971f9ff7 com.apple.HelpData 2.0.4 (34) <9128FFEB-0F6C-B273-FCF4-D87A20227345> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData 0x971fa000 - 0x97264fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib 0x97265000 - 0x972b6ff7 com.apple.HIServices 1.8.0 (???) <10C85B88-C6AF-91DB-2546-34661BA35AC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x977b2000 - 0x9782dfe7 com.apple.audio.CoreAudio 3.2.2 (3.2.2) <51D0E2DC-B15F-AF6C-70D8-026DDAD4E2A5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x97a11000 - 0x97a91feb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x97b01000 - 0x97b15ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x97b16000 - 0x97ec4fe3 com.apple.RawCamera.bundle 3.3.0 (533) <05A38D21-8556-434C-8BAA-850A6EC99B37> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera 0x97ec5000 - 0x97ed2ff7 com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x97f2a000 - 0x97f34fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound 0x97f6a000 - 0x9828afeb com.apple.CoreServices.CarbonCore 861.13 (861.13) <52803668-3669-36BD-57DD-078FBA835081> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x9828b000 - 0x98355fef com.apple.CoreServices.OSServices 357 (357) <CF9530AD-F581-B831-09B6-16D9F9283BFA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x983cf000 - 0x983f7ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib 0x983f8000 - 0x983fcff7 IOSurface ??? (???) <66E11D8E-CF4B-EFD0-37F9-20177C647021> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x98405000 - 0x98405ff7 com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib 0x98406000 - 0x98409fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib 0x9844b000 - 0x98501ffb libFontParser.dylib ??? (???) <067DC1A2-764B-41EA-B07E-4205472749B7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib 0x98502000 - 0x985b2ff3 com.apple.ColorSync 4.6.3 (4.6.3) <AA1076EA-7665-3005-A837-B661260DBE54> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x985b3000 - 0x985d5fef com.apple.DirectoryService.Framework 3.6 (621.3) <05FFDBDB-F16B-8AC0-DB42-986965FCBD95> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService 0x985d6000 - 0x989ecff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x98a75000 - 0x98cd9fef com.apple.security 6.1.1 (37594) <3F68A006-6B30-85D5-1A75-8D748F72A6D5> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x98ce5000 - 0x98d9efe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib 0x98e38000 - 0x98e73feb libFontRegistry.dylib ??? (???) <A102F61F-25D5-001A-20C3-56304C585072> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x98f93000 - 0x98fd5ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x98fd6000 - 0x99026ff7 com.apple.framework.familycontrols 2.0.1 (2010) <B9762E20-543D-13B9-F6BF-E8585F04CA01> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls 0x990dd000 - 0x9918afe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib 0x9918b000 - 0x99196ff7 libGL.dylib ??? (???) <B87E0676-F5EF-8DA3-6DEE-13C43B3832A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x9937d000 - 0x99489ff7 libGLProgrammability.dylib ??? (???) <1B315838-F477-5416-7504-67EC3433AD4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib 0x9953b000 - 0x99588feb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer 0x99589000 - 0x9970bfe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <2314BD12-0821-75BB-F3BC-98D324CFD30A> /usr/lib/libicucore.A.dylib 0x9970c000 - 0x99713ff3 com.apple.print.framework.Print 6.1 (237.1) <97AB70B6-C653-212F-CFD3-E3816D0F5C22> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x99714000 - 0x99725ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x99726000 - 0x997d4ff3 com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x997d5000 - 0x997dcff7 com.apple.agl 3.0.12 (AGL-3.0.12) <6877F0D8-0DCF-CB98-5304-913667FF50FA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL 0x997dd000 - 0x9984cff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x998cc000 - 0x99969fe3 com.apple.LaunchServices 362.1 (362.1) <885D8567-9E40-0105-20BC-42C7FF657583> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x9996a000 - 0x9997cff7 com.apple.MultitouchSupport.framework 204.13 (204.13) <F91A4E32-01AA-49DB-2205-3DBE1FEFFC43> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <3441F338-2218-6D36-3F95-3A16FBF6713D> /usr/lib/libSystem.B.dylib Model: iMac8,1, BootROM IM81.00C1.B00, 2 processors, Intel Core 2 Duo, 2.8 GHz, 4 GB, SMC 1.30f1 Graphics: ATI Radeon HD 2600 Pro, ATI Radeon HD 2600 Pro, PCIe, 256 MB Memory Module: global_name AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8C), Broadcom BCM43xx 1.0 (5.10.91.27) Bluetooth: Version 2.3.3f8, 2 service, 19 devices, 1 incoming serial ports Network Service: Ethernet, Ethernet, en0 Serial ATA Device: WDC WD5000AAKS-40YGA1, 465.76 GB Parallel ATA Device: MATSHITADVD-R UJ-875 USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8502, 0xfd400000 USB Device: Hub, 0x2001, 0xf103, 0xfa400000 USB Device: LaCie Hard Drive USB, 0x059f (LaCie), 0x0351, 0xfa460000 USB Device: USB2.0-CRW, 0x0bda (Realtek Semiconductor Corp.), 0x0158, 0xfa420000 USB Device: CardReader, 0x07cc, 0x0500, 0xfa450000 USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x5d100000 USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x1a100000 USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x820f, 0x1a110000 FireWire Device: unknown_device, Unknown FireWire Device: unknown_device, Unknown gholmes
Austin, Texas |
| Posted: November 7, 2010 12:50 pm | ||||||
Adu
Posts: 20 |
I have always ran Filter Forge along side Photoshop CS3 and Paintshop Pro 7 and also with a few internet windows open and also a virtual environment open with no issues. My issue started a few days ago. I cannot even open it now by itself. Could it be due to a bad Windows update? Should I just uninstall and reinstall?
True wisdom knows it knows nothing. |
| Posted: November 12, 2010 10:34 pm | ||||||
Posts: 3505 |
Adu, do you use Comodo software or PC Doctor?
| Posted: November 13, 2010 3:47 am | ||||||
Adu
Posts: 20 |
No GMM I am not running either. However, I did notice the change directly after a certain pop up window came up from my system about "Data Execution Prevention". Directly after I could not open Filter Forge. I am running XP Pro. I also have 2 gbs of ram on my system. I have NOT made any changes to the hardware or software of my computer recently. I do have the Filter Forge CD. I am just curious as to what could have triggered this recent block on the program itself? I do happen to open/download and run a lot of the filters from the online library.
I did do a search on how to disable this "Data Execution Prevention". And found this site: http://www.zensoftware.co.uk/kb/article.aspx?id=10002 When going to the path to change things in notepad I have this: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Professional"=optin /fastdetect ~~~~~~~~~~~~~~~~~~~~~~~~~ Thing is my computer is not even partitioned
So I am leery of making any changes as yet. Could partition (2) be referring to my external 500 gb HD? True wisdom knows it knows nothing. |
| Posted: November 13, 2010 1:30 pm | ||||||
Adu
Posts: 20 |
Uninstalled and reinstalled Filter Forge. It still would not execute. I did what the site above said to do with the "Data Execution Prevention". Filter Forge still will not run on my computer.
So what is next? I was really excited about purchasing this last year? I might as well turn the CD into a Frisbee? True wisdom knows it knows nothing. |
| Posted: November 14, 2010 10:46 pm | ||||||
GMM, I think this is the same problem as I reported during beta testing. I'm having the same problem now with the free packs.
Main FF2 works fine now, but the free packs never start up. Following the process in the task manager shows that it runs for 5-20 secs and then dies. No GUI, no error messages, just gone. Back then with the beta I solved it by uninstalling all FF versions, back up my filters to another folder and then search for everything FF related both on disk and in registry and remove it (except the backed up filters of course). I couldn't pinpoint the problem, but this overkill operation fixed it. Perhaps you can replicate the error by installing one of the free packs. |
| Posted: November 15, 2010 1:28 am | ||||||
Posts: 3505 |
Adu, please disable all antivirus/debuggers and try to run again.
Also, try to boot in Safe mode and run Filter Forge. |
| Posted: November 19, 2010 3:01 am | ||||||
Adu
Posts: 20 |
All is well GMM. It was a few bugs on my PC which Kasperski 2010 caught. The two I had were Backdoor.Win32.Papras.xx and HackTool.Win32.Kiser.il. Let it be known anyone that they did keep the app from executing. My apologies.
| Posted: November 24, 2010 1:01 pm | ||||||
136 unregistered users.
