Anine
Posts: 18 |
This can be installed to either Adobe or Ulead, but I can't seem to get the transperancy to work in Ulead Photo Impact 12 and when using FF alone it's the same. What do I do wrong?
| Posted: June 5, 2008 5:27 am | ||
Posts: 3505 |
Does the problem occur when creating filters or when applying an existing one?
If you are building a filter and use the Color control, you cannot set the transparency directly. Use the Set Alpha component. |
| Posted: June 5, 2008 9:04 am | ||
Anine
Posts: 18 |
It is when using existing filters and checking transperancy.
| Posted: June 5, 2008 9:06 am | ||
| ssamm |
IWeber,
I'm not sure if this is what you're talking about, but: If a filter does not have the Image component hooked up, then the transparent parts will not be transparent (but rather you'll see the image on those parts). E.g. Look inside the attached filter. Notice that the switch component does nothing, but if it's not there, then the image will appear in the transparent parts. transptest.ffxml |
| Posted: June 5, 2008 9:31 am | ||
21 unregistered users.
