Firemup
Filters: 28
Adding component to Result>Reflectivity>Reflective Blur caused FF bug report to be generated. Sent the report but did manage to save the filter by removing the plugs.
Prior to that, FF crashed twice. Once when adding Stair Step end control and Stair Step start controls. When application closed, I received this message.
This happened twice. Once after receiving the Filter Forge message listed below.
Paint Shop Pro X: Program passed bad parameters
Plugin passed bad parameters
This happened once.
Filter Forge X86-SSE2 - Exception caught at thread 00000FDC
<class XFW::Kernel""System Exception>Access violation at address 00466931 (read at address 3F462C93)
I clicked ok and was able to reopen FF. Repeated the same add control steps, FF crashed and the above messages were generated. I removed components added others and as I added controls, the bug report was generated.
Reproducible irregardless of removing one component for another.
Firemup
Firemup, could you please post the exact steps to reproduce the problem? Here's an example:
1. Start Filter Forge under PaintShop Pro
2. Click the "Filter Editor" button
3. Choose "Create a new filter"
4. Select the Result component and set the type to Surface
5. ...
6. ...
Every bit of information will be helpful, so please describe everything in as much details as possible, just keep it in the step-by-step format as shown in the example above.
Firemup
Filters: 28
This is the filter I was working on when the crash happened. If I added controls to bias or wave such as Start>End or Min>Max, the crash occurred. FF closed but I could reopen it due to changes had not been saved. If I added Reflection Blur and Reflectivity, the Bug Report occurred. I was able to pull the plugs from the result component to save the filter before sending the Bug Report.
<?xml version="1.0" encoding="utf-8"?>
<Filter>
<Components>
<Result id="result">
<Height source="tonecurve 04"/>
<Reflectivity source="tonecurve 02" value="0"/>
<ReflectionBlur value="0"/>
<Metallic source="tonecurve 03" value="0"/>
<FilterType value="1"/>
<Lighting>
<Height value="0.2"/>
<Environment>
<Source value="Church"/>
<Saturation value="1"/>
<Rotation value="0"/>
</Environment>
</Lighting>
</Result>
<AssembleHSB id="assemblehsb 01">
<H source="intslidercontrol 01" value="0.36">
<Minimum value="0"/>
<Maximum value="3.6"/>
</H>
<S source="intslidercontrol 03" value="0.75">
<Maximum value="1"/>
<B value="1"/>
</AssembleHSB>
<BiasCurve id="biascurve 01">
<Bias value="0.6"/>
<End value="1"/>
<Image id="image 01"/>
<IntSliderControl id="intslidercontrol 01">
<Name value-en="Hue"/>
<UseRemapping value="true"/>
<Value value="7"/>
<RangeMax value="20"/>
<Name value-en="Stairs Start"/>
<Value value="7"/>
<Name value-en="Saturation"/>
<UseRemapping value="false"/>
<Value value="7"/>
<Name value-en="Vertical"/>
<Value value="5"/>
<Name value-en="Horizontal"/>
<Value value="5"/>
<Name value-en="Threshold"/>
<Value value="7"/>
<Name value-en="Stairs End"/>
<Value value="7"/>
<ProfileGradient id="profilegradient 01">
<Color1 red="0" green="0" blue="0" alpha="1"/>
<Color2 red="1" green="1" blue="1" alpha="1"/>
<Offset value="0"/>
<Rotate value="0"/>
<Repeat value="1"/>
<Profile source="wavecurve 01" value="2"/>
<Mirror value="false"/>
</ProfileGradient>
<ProfileGradient id="profilegradient 02">
<Offset value="0"/>
<Rotate value="0"/>
<Repeat value="1"/>
</ProfileGradient>
<StairsCurve id="stairscurve 01">
<Threshold value="0.5"/>
<Smooth value="0.1"/>
<Start source="intslidercontrol 02" value="0">
<End source="intslidercontrol 09" value="1">
</End>
<Linear value="false"/>
<Threshold source="intslidercontrol 08" value="0.5">
</Threshold>
<Shape value="0"/>
<Invert value="false"/>
<Selector source="intslidercontrol 04" value="1">
<Step value="1"/>
<Source2 source="profilegradient 01" red="1" green="0" blue="0" alpha="1"/>
<Source3 red="0" green="1" blue="0" alpha="1"/>
<Source4 red="0" green="0" blue="1" alpha="1"/>
<Source5 red="0" green="1" blue="1" alpha="1"/>
<Selector source="intslidercontrol 05" value="1">
<Step value="1"/>
<Source2 source="profilegradient 02" red="1" green="0" blue="0" alpha="1"/>
<ToneCurve id="tonecurve 01">
<Source source="tonecurve 02"/>
<Curve source="stepcurve 01"/>
<PreserveColor value="true"/>
</ToneCurve>
<ToneCurve id="tonecurve 02">
<Source source="tonecurve 03"/>
<Curve source="stairscurve 01"/>
</ToneCurve>
<ToneCurve id="tonecurve 03">
<Source source="tonecurve 04"/>
</ToneCurve>
<ToneCurve id="tonecurve 04">
<Source source="image 01"/>
<Curve source="biascurve 01"/>
</ToneCurve>
<WaveCurve id="wavecurve 01">
<Shape value="0"/>
<AVariance value="0"/>
<FVariance value="0"/>
<Phase value="0"/>
<Wave value="3"/>
<Frequency value="0.01"/>
<Variation value="1"/>
<Randomizable value="true"/>
</WaveCurve>
</Components>
<Presets>
<DefaultPreset>
<Settings size_factor="1" variation="1" seamless="false" antialiasing="2" map_type="0" edges_only="true"/>
<Lighting>
<Environment>
<Brightness value="1"/>
</Environment>
</Lighting>
<Controls>
<Value value="7"/>
<Value value="7"/>
<Value value="7"/>
<Value value="7"/>
</Controls>
</DefaultPreset>
<Preset>
<Settings size_factor="3.40037" variation="9025" seamless="false" antialiasing="2" map_type="0" edges_only="true"/>
<Lighting>
<Environment>
</Environment>
</Lighting>
<Controls>
<Value value="17"/>
<Value value="17"/>
<Value value="7"/>
<Value value="7"/>
</Controls>
</Preset>
<Preset>
<Settings size_factor="4.29" variation="22927" seamless="false" antialiasing="2" map_type="0" edges_only="true"/>
<Lighting>
<Height value="0.5"/>
<Environment>
<Source value="Entrance, Day"/>
<Brightness value="0.85"/>
<Saturation value="0.34"/>
</Environment>
</Lighting>
<Controls>
<Value value="13"/>
<Value value="18"/>
<Value value="7"/>
<Value value="14"/>
</Controls>
</Preset>
<Preset>
<Settings size_factor="6.13695" variation="23659" seamless="false" antialiasing="2" map_type="0" edges_only="true"/>
<Lighting>
<Environment>
</Environment>
</Lighting>
<Controls>
<Value value="3"/>
<Value value="19"/>
<Value value="7"/>
<Value value="1"/>
</Controls>
</Preset>
<Preset>
<Settings size_factor="2.42912" variation="12196" seamless="false" antialiasing="2" map_type="0" edges_only="true"/>
<Lighting>
<Height value="0.41"/>
<Environment>
<Source value="Forest"/>
</Environment>
</Lighting>
<Controls>
<Value value="19"/>
<Value value="19"/>
<Value value="17"/>
<Value value="10"/>
</Controls>
</Preset>
<Preset>
<Settings size_factor="2.35557" variation="13415" seamless="false" antialiasing="2" map_type="0" edges_only="true"/>
<Lighting>
<Height value="0.28"/>
<Environment>
<Source value="Spring"/>
<Brightness value="1.5"/>
</Environment>
</Lighting>
<Controls>
<Value value="13"/>
<Value value="16"/>
<Value value="7"/>
<Value value="11"/>
</Controls>
</Preset>
</Presets>
<FilterEditor>
<ThumbnailSize value="1"/>
<Viewport left="0" top="98" zoom_factor="1"/>
<LockPreview>
<Locked value="true"/>
<LockedComponent name="result"/>
</LockPreview>
<Item id="assemblehsb 01">
<Position left="300" top="-425"/>
<Position left="1525" top="-275"/>
<Position left="1550" top="-625"/>
<Position left="550" top="-600"/>
<Position left="1475" top="0"/>
<Position left="550" top="-450"/>
<Position left="2000" top="100"/>
<Position left="2000" top="350"/>
<Position left="975" top="175"/>
<Position left="1475" top="125"/>
<Position left="2250" top="-75"/>
<Position left="2250" top="250"/>
<Position left="25" top="-25"/>
<Position left="1175" top="0"/>
<Position left="725" top="150"/>
<Position left="1700" top="50"/>
<Position left="1700" top="275"/>
<Position left="450" top="-25"/>
<Position left="675" top="-250"/>
<Position left="950" top="-375"/>
<Position left="1275" top="-575"/>
<Position left="2525" top="75"/>
</FilterEditor>
</Filter>
Firemup
Firemup
Filters: 28
Update on MetalFlake filter. I started making modifications to the build when noticing the metalflake effect was no longer viewable after having submitted it earlier today. This is the report:
Bug Reports were generated. Filter was irrecoverable and is now trashed. Please delete it from the queue
Result
Blend Surface Color
Blend Height
Tone Curve Reflectivity
Bias Curve w/Start - End sliders
Profile Gradient w/Image as Color 1, 2 and Offset
Wave Profile w/Maximum and Wave sliders
Added Blend to Reflection Blur and Bug report occurred. Removed Reflection Blur plug and
Bug report #2 occurred.
Sent bug reports.
Continuing with modifications, I switched Blend to Color Dodge after changing it to Height
and Reflection Blur. New Internal Error occurred: <class XFW::StateError> Specular exponent
0.924495 is too small (less than 1) for environment 01BD41E0
Sent bug report after changing blend mode
Closed Filter Editor and this Internal Error occurred: <class XFW::StateError> Specular exponent
0.994883 is too small (less than 1) for environment 01BD4B60.
Firemup
onyXMaster
Filter Forge, Inc.
The error "<class XFW::StateError> Specular exponent
0.XXXXXXXX is too small (less than 1) for environment XXXXXXXX." is already fixed (the fix will appear in the next release).
We're more interested in the origins of "<class XFW::Kernel""System Exception>Access violation at address 00466931 (read at address 3F462C93)". Could you please provide more data on that crash?
Firemup
Filters: 28
There's nothing listed in the Application Log.
Firemup
33,857 Registered Users
+44 new in year!
101 unregistered users.
