MikiNotD
Hi,
Help!
I tried to open FF in Photoshop CS2 yesterday. It was working ok until then. I got this error message:
<class XFW::StateError> Could not read filter 'Cloth Creator', status (6), client version required (0.000).
Now FF won't open.
I've try to attached the Bug Report file, but this forum program gives me the message: "Incorrect file type or maximum size of the file exceeded (.txt)!" I'll send in that file through regular channels I guess.
Thanks.
Michael smile:?:
Mik
Bella
Filter Forge, Inc.
Mik,
Please go to this location on your computer:
%APPDATA%\Filter Forge\System\Library (by default it is C:\Documents and Settings\YourUserName\Application Data\Filter Forge\System\Library),
find the file "Library_2209-1.ffxml" (it's the "Cloth Creator" filter) and post it here.
Then delete the filter file from your computer. After this, Filter Forge should open. Meanwhile, we'll look into the problem.
crispalomino
I'm getting internal errors, but in the standalone. Sometimes it gives me the option to generate a bug report, other times, it persists in not letting me or shutting it down or the program. If I am able to get to the task manager, sometimes I can end Filter Forge, but often I can't turn off the "generate bug report" window and eventually must restart the system.
I am on my new PC with Vista, 3gb ram, Intel Core2 Quad,Nvidia 8800GT, 512 vram.
Thank you,
Cris
Bella
Filter Forge, Inc.
Cris,
what kind of errors are you getting? what is the error message? something like MikiNotD cited above? if not, please post what you are getting or send us a bug report.
(I do have two bug reports from you with the FillRgn thing. if you mean this, there's no need to post it. yes, i know it's an irritating kind of error but we are already perfectly aware it exists, we can reproduce it, and i do hope it will soon be fixed.)
S. C. Danmola
Owner
Am getting the same below. How can I solve the problem?
<class XFW::OSCallError> ::WriteFile(block 4, parent pipe 000004B4, slave pipe 0644C360) failed with error code 0x000000E8: The pipe is being closed.
Operating system: x64 Edition (6.2 build 9200)
Physical memory: 3682 MB
Number of processors: 2, available: 2
Processor info: AMD E-300 APU with Radeon™ HD Graphics, ~1295 MHz
Filter Forge x86 4.013.34537.39570 Release, December 19, 2014 13:21 [4/12/2015 6:25:30 AM Central Daylight Time]
left top panel
left bottom panel
left panel
right panel
category panel
filters panel
Exception reported at thread 00000FFC 'FetchingMgr 06A82DC8':
Possible original exception location:
<unknown file>(0) : <unknown function>()+0 at 008D642F in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 008DB6A8 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 008DA002 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 008DA046 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 007629AC in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006ED2A5 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006ED356 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006ED103 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 007538FC in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00B1C513 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00740C01 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00754F10 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00753B16 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00474552 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 008E77B4 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 008E2430 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 004731F2 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 008D8430 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 008D87A0 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 008E545C in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : BaseThreadInitThunk()+36 at 77097C04 in C:\WINDOWS\SYSTEM32\KERNEL32.DLL
<unknown file>(0) : RtlInitializeExceptionChain()+90 at 7780B51A in C:\WINDOWS\SYSTEM32\ntdll.dll
CONTEXT_CONTROL: CS:EIP 0023:76764598, SS:ESP 002B:181EF460, EBP 181EF4B8, FLAGS 00000216
CONTEXT_INTEGER: EAX 181EF460, EBX 181EF634, ECX 00000003, EDX 00000000, ESI 00B78594, EDI 181EF4F8
Exception caught at thread 0000197C 'Application':
left panel
left panel
left top panel
left bottom panel
<unknown file>(0) : <unknown function>()+0 at 00911B46 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 009121EB in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00916C67 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00916C58 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
Exception reported at thread 000012B8 'RenderingMgr 128461F8/0':
<unknown file>(0) : <unknown function>()+0 at 1925E188 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00CF22F4 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00A03DF4 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 007C25EB in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 007C2619 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 0073F7BB in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00754C4B in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 0071B5CF in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 0071C94F in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 007DD05D in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00753C26 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00A24F1F in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00A29E99 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 007E3626 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 0071B372 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 0071D539 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 0073979E in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00735419 in C:\Program Files (x86)\Filter Forge 4\Bin\Filter Forge x86.exe
CONTEXT_CONTROL: CS:EIP 0023:76764598, SS:ESP 002B:1925E078, EBP 1925E0D0, FLAGS 00000216
CONTEXT_INTEGER: EAX 1925E078, EBX 1925E24C, ECX 00000003, EDX 00000000, ESI 00B78594, EDI 1925E110
[TimeStamp: 503458]
[FFXLib::RenderingManager] Failed filter dump:
<?xml version="1.0" encoding="utf-8"?>
<Filter>
<Components>
<Result id="result">
<FilterType value="0"/>
<Lighting>
<Height value="0.20000000000000001"/>
<Environment>
<Source value="Church"/>
<Saturation value="1"/>
<Rotation value="0"/>
<RotationAxis x="0" y="0" z="0"/>
</Environment>
<Ambience>
<AmbientLight red="0" green="0" blue="0"/>
<Shadowing value="0"/>
<CurrentOcclusionSettings>
<RayDirections value="4"/>
<TraceDistance value="0.20000000000000001"/>
<RayJittering value="true"/>
<RayBounce value="true"/>
<AvoidStreaks value="true"/>
<DirectSamples value="0"/>
<ROQuality value="3"/>
</CurrentOcclusionSettings>
<CustomOcclusionSettings>
<RayDirections value="16"/>
<TraceDistance value="0.29999999999999999"/>
<DirectSamples value="1"/>
<ROQuality value="10"/>
</CustomOcclusionSettings>
<ArtisticSettings>
<BlackPoint value="0"/>
<Midtones value="0.5"/>
<WhitePoint value="1"/>
</ArtisticSettings>
</Ambience>
</Lighting>
</Result>
<Blend5 id="blend 01">
<Mode value="7"/>
<Foreground source="blur 02" red="1" green="1" blue="1" alpha="1"/>
<Background source="blur 01" red="0" green="0" blue="0" alpha="1"/>
<Opacity value="1"/>
<Source source="tiles 02"/>
<Radius source="slidercontrol 01" value="0.029999999999999999">
<Minimum value="0"/>
<Maximum value="0.29999999999999999"/>
</Radius>
<Gaussian value="true"/>
<Source source="tiles 01"/>
<Radius source="slidercontrol 03" value="0.029999999999999999">
<Maximum value="0.10000000000000001"/>
</Radius>
<CheckboxControl id="checkboxcontrol 01">
<Name value-en="Row Shift"/>
<UseRemapping value="false"/>
<Checked value="true"/>
</CheckboxControl>
<PerlinNoise2 id="perlinnoise 01">
<Noise red="1" green="1" blue="1" alpha="1"/>
<Roughness value="0.20000000000000001"/>
<Scale value="2.5"/>
<Stretch value="0"/>
<Angle value="0"/>
<Details value="1"/>
<Contrast source="slidercontrol 02" value="0.29999999999999999">
<Maximum value="0.69999999999999996"/>
</Contrast>
<Variation value="1"/>
<OctaveCurve value="0"/>
</PerlinNoise2>
<SliderControl id="slidercontrol 01">
<Name value-en="Blur Radius"/>
<UseRemapping value="true"/>
<Value value="0.76000000000000001"/>
<Name value-en="Dot Size Variation"/>
<Value value="0.54000000000000004"/>
<Name value-en="Glow"/>
<Value value="0.24358099999999999"/>
<Tiles id="tiles 01">
<Color source="image3 01" red="0.69999999999999996" green="0.46600000000000003" blue="0.34999999999999998" alpha="1"/>
<Mortar red="1" green="1" blue="1" alpha="0"/>
<HRange value="0.050000000000000003"/>
<LRange value="0.14999999999999999"/>
<MortarWidth source="perlinnoise 01" value="0.12"/>
<BevelWidth value="0.20000000000000001"/>
<Corners value="1"/>
<FillMode value="2"/>
<RowShift source="checkboxcontrol 01" value="false">
<Invert value="false"/>
</RowShift>
<RepeatH value="5"/>
<RepeatV value="5"/>
<Chaos value="0.14999999999999999"/>
<Bevel value="1"/>
</Tiles>
<Tiles id="tiles 02">
<Mortar source="image3 01" red="0" green="0" blue="0" alpha="1"/>
<SRange value="0.25"/>
<MortarWidth source="perlinnoise 01" value="0"/>
<BevelWidth value="0"/>
</RowShift>
<Bevel value="0"/>
</Tiles>
</Components>
<GroupNames/>
<Presets>
<DefaultPreset preview_image="LADYBUG_OPAQUE">
<Settings size_factor="2.00183" variation="17437" seamless="false" antialiasing="2" map_type="0" edges_only="true" clip_hdr_for_result="true"/>
<Lighting>
<Environment>
<Brightness value="1"/>
</Environment>
<Ambience>
<ArtisticSettings>
</ArtisticSettings>
</Ambience>
</Lighting>
<Controls>
</CheckboxControl>
</Controls>
</DefaultPreset>
</Presets>
</Filter>
[FFXLib::RenderingManager] Rendering settings dump:
Seed: 17437
Seamless: false
Optimize blur radius: true
Supersample explicit inputs: false
Output size: 600x600
Sampling rate: 6
Supersampling kernel: 2
Jitter: 0
Bruteforce: false
High precision bitmap: false
Blend with original image: true
[FFXLib::RenderingManager] Rendering storage: <class FFX::PreviewRenderingStorage>@053F1920
[FFXLib::RenderingManager] Failed rendering block dump:
Block origin: 0;0
Root component: result
Sampling source component: result
Progressive pass: 4
Exception reported at thread 00001600 'RenderingMgr 1DC387D0/0':
<unknown file>(0) : <unknown function>()+0 at 1925E838 in Filter Forge x86.exe
CONTEXT_CONTROL: CS:EIP 0023:76764598, SS:ESP 002B:1925E728, EBP 1925E780, FLAGS 00000216
CONTEXT_INTEGER: EAX 1925E728, EBX 1925E8FC, ECX 00000003, EDX 00000000, ESI 00B78594, EDI 1925E7C0
[TimeStamp: 503582]
<Filter>
<Components>
<Lighting>
<Environment>
</Environment>
<Ambience>
<ArtisticSettings>
</ArtisticSettings>
</Ambience>
</Lighting>
</Result>
<Mode value="14"/>
<Foreground source="distort 01" red="1" green="1" blue="1" alpha="1"/>
<Background source="distort 02" red="0" green="0" blue="0" alpha="1"/>
<Mode value="14"/>
<Foreground source="blend 01" red="1" green="1" blue="1" alpha="1"/>
<Background source="distort 03" red="0" green="0" blue="0" alpha="1"/>
<NoiseDistortion2 id="distort 01">
<Source source="image2 01"/>
<Distortion source="slidercontrol 01" value="1">
<Maximum value="1"/>
</Distortion>
<Roughness source="slidercontrol 02" value="0">
</Roughness>
<Angle value="0"/>
</NoiseDistortion2>
<NoiseDistortion2 id="distort 02">
</Distortion>
</Roughness>
<Angle value="0"/>
<Variation value="2"/>
</NoiseDistortion2>
<NoiseDistortion2 id="distort 03">
</Distortion>
</Roughness>
<Angle value="0"/>
<Variation value="3"/>
</NoiseDistortion2>
<Image2 id="image2 01">
<ScalingMode value="0"/>
<Name value-en="Distortion"/>
<Value value="0.20000000000000001"/>
<Name value-en="Turbulence"/>
<Value value="0.5"/>
</Components>
<GroupNames/>
<Presets>
<DefaultPreset preview_image="LIFESAVER_OPAQUE">
<Lighting>
<Environment>
</Environment>
<Ambience>
<ArtisticSettings>
</ArtisticSettings>
</Ambience>
</Lighting>
<Controls>
</Controls>
</DefaultPreset>
</Presets>
</Filter>
Seed: 1
Seamless: false
Sampling rate: 6
Jitter: 0
Bruteforce: false
[FFXLib::RenderingManager] Rendering storage: <class FFX::PreviewRenderingStorage>@1EDF2A18
Block origin: 0;0
Progressive pass: 4
SCDanmola
15 unregistered users.
