Junes Designz
June's Designz
Filters: 11
I cannot seem to update my filter forge to load into the newest version of PSP. I have unloaded i nd reloaded it and it still will not intergrate with PSP XII
What do you think should do? smile:(
Any help would be appreciated!
Thnx
June
Bella
Filter Forge, Inc.
Corel Paint Shop Pro XII is not an officially supported host application. It's not surprising that Filter Forge will not work with it.
Perhaps we'll look into it, and it will probably be added to the list of supported hosts later, but I cannot promise anything now.
Currently, if you manage to install Filter Forge under PSP XII and use it -- it's at your own risk, we cannot guarantee that it will work properly.
james, i dont have XII, but i do have XI. just take the .8bf file of filter forge and drop it in the plugins folder of psp. if you've installed everything else correctly with FF, this shld work. as far as i know XII shld still use .8bf files correctly.
onyXMaster
Filter Forge, Inc.
I recommend copying entire plugin folder, not just the Filter Forge.8bf file.
Try to copy the "\Program Files\Filter Forge\Plugin" folder to the PSP plugins folder, and rename it to "Filter Forge" (renaming is not necessary, should be done to prevent possible name clashes).
Manatee
Filter Forge works good in PSP XI and X2 here, no problem without doing something special
21 unregistered users.
