Hi FF Team,
Currently the Profile Gradient is categorized as a discrete filter - is that really necessary? We specifically define if its a horizontal or a vertical gradient via the rotation settings, so it should be possible to make the gradient span follow the related image side size? You could add a checkbox called "relative" or "proportional" or something perhaps.. This issue may not categorize as a bug, but it certainly is very annoying Besides from that, FF is great! |
| Posted: November 7, 2007 2:04 am | ||
| jffe |
It's because of the seamless tiling. You might try doing a search about it in the forums for further info and/or words directly from the FF crew, it's been brought up before and is under consideraton for V2 I believe. Meanwhile, we all agree of course, just saying, it's been asked for/about before.
jffe Filter Forger |
| Posted: November 7, 2007 2:29 am | ||
Right, I was too fast there - well, now they know that at least one more would like a solution
| Posted: November 7, 2007 3:01 am | ||
sphinx, what do you mean by 'discrete' here? not questioning your use of it or if you have it right; i simply dont know and would like to.
| Posted: November 7, 2007 8:38 am | ||
Posts: 3505 |
@Kraellin: Filters that cannot be seamlessly tiled within an image with a non-integer aspect ratio are called discrete.
http://www.filterforge.com/more/help/...lters.html |
| Posted: November 7, 2007 8:48 am | ||
ah, thank you, gmm
| Posted: November 7, 2007 9:13 am | ||
29 unregistered users.
