sleepingdog
I've search and read several posts aobut downloading issue with FF
I've just downlaod and installed FF
and tried DL'ing filters what happens is I get this message
'Cannot Run Filterforge- the program is already running'
this happens if I run the program through Photopain/photoshope
and happens if I run FF as standalone
waht I've done
1. I have no firewall running (xp sp2)
2. closed out FF and went directly to FF website and tried downloading from there...what happens is the filter appears to start DL'ing then FF opens but all I get is the default filters..the newly download filter is not there
3. no proxy
4. have tried both FF online settings automatic and direct: same problem
any suggestions as to why I am unable to download filters
What browser version do you use?
Also, please try to open the following URL and report the results: http://www.filterforge.com/upload/filter_lib/697.ffcmd
Please do two tests: with Filter Forge running and with Filter Forge closed.
31 unregistered users.
