ronviers
Hi,
The first image is how the filter displays on the filter's website and the second image is how I expect it to display. The reason I expect it to display like the second image is that is how the first preset is set and also how the filter was saved. What determines how the image will be rendered for the website? Thanks for the time, Ron ![]() @ronviers |
| Posted: July 10, 2007 1:26 pm | ||||||||||
ronviers
| Posted: July 10, 2007 1:27 pm | ||||||||||
ronviers
DOH! I think I figured it out. I think I am a day behind. Nevermind...
The new one will post tomorrow Sorry, I will try to be more careful. @ronviers |
| Posted: July 10, 2007 1:30 pm | ||||||||||
| jffe |
It's always either the seamless tiling checkbox, or the size,pixels setting, those darn pixels still trick me sometimes ha-ha.
jffe Filter Forger |
| Posted: July 10, 2007 1:40 pm | ||||||||||
ronviers
![]() @ronviers |
| Posted: July 10, 2007 1:43 pm | ||||||||||
Rawn (RawArt)
The web generates the images dynamically from the filter....it really make my "Native art" filter look overly simplistic, when it was actually pretty cool looking in the presets LOL
| Posted: July 10, 2007 1:55 pm | ||||||||||
| jffe |
----Well, if you have the seamless tiling box checked, and size,pixels set to 600, then your presets should show up on the FF webpage exactly as you made them, and assuming you made 9, otherwise it will hit random for you for the remainder of the 9 example presets. jffe Filter Forger |
| Posted: July 10, 2007 2:03 pm | ||||||||||
Rawn (RawArt)
yeah...I learned very quick to make all my own presets LOL
I didnt know about that seamless thing though (though not all tiles work well seamless). I will keep that in mind Rawn |
| Posted: July 10, 2007 2:25 pm | ||||||||||
and i think the seamless thing only gets rendered by the website in texture types, not image types.
| Posted: July 10, 2007 2:41 pm | ||||||||||
ronviers
Hi,
Would someone please download this filter: http://www.filterforge.com/filters/3361.html and let me know what if what they see for see for the first preset looks like the first image shown above or the second? Thanks, Ron ![]() @ronviers |
| Posted: July 12, 2007 4:04 am | ||||||||||
ron it the tiling doing it - tick the tiling on your filter and see what happens
| Posted: July 12, 2007 4:12 am | ||||||||||
ronviers
You're right. I don't know what to do. If the users cannot see the interaction between the two noises then it's just a vanilla pattern. What should I do?
![]() @ronviers |
| Posted: July 12, 2007 4:17 am | ||||||||||
having a fiddle but its not easy to reproduce your lovely effect can get variable interesting result - give me a bit time and I'll get back to you
| Posted: July 12, 2007 5:14 am | ||||||||||
ronviers
@ronviers |
| Posted: July 12, 2007 5:17 am | ||||||||||
ron there's good news and there bad news - the good news I haven't give up - the bad news I haven't fixed it - tryed many approaches and can get some interesting results but none that emulates the same effect, I don't know of any filter that is demolished as badly from the tilling as this one -you can get sudo effects similar but that particular layering is lost - maybe some one else reading this can have a crack at it - it's a challenge, and I might be missing a simple solution.
Sorry to disappoint you ron I'll keep trying |
| Posted: July 14, 2007 1:11 am | ||||||||||
ronviers
Hi Carl – I can’t thank you enough to taking a look at this. I failed to consider, or even notice, the tiling limitations inherent with some filters.
I really thought I had a winner with this one, I liked playing with it and I could hardly wait to post it, but now I’m embarrassed by it. If it can’t be fixed are there uses for a non-tiling pattern? What is the procedure for removing unwanted filters? I'm really on a roll - that's three rejects in a row. ![]() @ronviers |
| Posted: July 14, 2007 7:06 am | ||||||||||
Hey ron I found a very simple way to almost give the same effect - you'll kick your self when you see the solution cause I kicked myself for not going back and picking up a simple thing - as I say it not the exactly the same result but you might think it's close enough - keep smiling
gbs21.ffxml |
| Posted: July 14, 2007 7:54 am | ||||||||||
ronviers
Unbelievable!!
It took me a while to run it down. The first thing I *had* to do was put the components back in order. It's impossible for me to think otherwise. I have never had an editor before – it’s very cool. I hope you let me return the favor some day – not that I’m qualified. I have had my work audited before. I can tell you one thing – if you are the reason several lawyers in suits are sitting around a big table – you had better be right. I was. If you ever want to collaborate on a filter let me know – I’m your man.
BTW, which of your filters is your favorite - the one you are most proud of? @ronviers |
| Posted: July 14, 2007 9:32 am | ||||||||||
LOL I had to put them in order to understand what you'd done
Well I hope you made them earn there money
Alway open to anything
Thats a tuffy, let see well - best upgraded filter would have to be Light and Shadow mainly cause originally the shadows sat on the surface of the image, but I managed to work out a displacement snippet that allowed the shadows to wrap around the object within the pic. Which I then used in Pryromaniac to get the flames to wrap.I guess Atmosphere and Abstraction Painter series, Pryro and xplode are my favorites. What about you Ron what's your favorite
Glad I could help with your filter cheers |
| Posted: July 15, 2007 7:51 am | ||||||||||
ronviers
LOL! That's about 1fourteen filters! It's really really hard to cut it down to one I have looked a little at a few and will try to get to more later tonight. My favorite? - I don't know... technically, I guess reposition rays or resize/crop/move. Aesthetically they all fall short - but I'm learning! @ronviers |
| Posted: July 15, 2007 5:44 pm | ||||||||||
very clever your latest bunch have excellent |
| Posted: July 18, 2007 3:26 am | ||||||||||
30 unregistered users.
