Stormy
So I have been playing around with Filter Forge and learning it a bit. Today when I tried using it from within photoshop the option was greyed out. So I tried opening Filter Forge on its own and it works fine.
Thanks for the help smile:)
ssamm
Filters: 21
I once had a similar problem.
I opened a black and white image in PS, and PS said that the image had an outdated ICC profile and it would ignore the profile -- but I could still work on the image. But PS grayed out the Filter Forge option in the filters section, so that I couldn't use it. However if I open the image in FF, FF can still work with it.
P.S. I just tried this out again and noticed that PS also grayed out a lot of it's own options like "color balance" too. So with that B&W image, it seems PS can't give it any color.
I'm not sure if Stormy's problem has anything related to this, but thought it might help...
Stormy
Hmm...Didnt think of that, It was a greyscale image. I will try that out when I get back home. Thanks ssamm!
This is probably caused by the fact that the image you opened or created had a bit depth unsupported by Filter Forge. Make sure that your image is not an indexed color image (all GIFs and usually some PNGs and BMPs have indexed colors). A safe option would be RGB 8, 16 or 32 bit.
19 unregistered users.
