Redcap
Some errors I have recieved as of late.
Before the update: I was editing a certain filter of mine and going back and forth between the edit mode and the main window. All of a sudden Filter Forge closed with the message saying that I could generate a bug report. I hit okay, and a window popped up asking me if I would like to generate a bug report, so I hit okay again, and another window popped up. I hit close, and a new window popped up. So no matter what I did a new error message would pop up with a new error name. I tried to open FF again to see if it would close the window but I got a message saying FF was already running (presumably referencing the generate report window.) I finally had to hit ctrl. alt delete and shut down the error message with the system manager. I gathered some information about this bug, namely the error numbers and they are as follows: I didn't submit this report because I thought it was just a gliche with the old FF; however, I have sense had a very similiar occurence(after downloading the new update): but the issue has seemed to escalate. This time around I was working on a pretty beefy filter and FF close with a generate report message appearing. Like before I could not get rid of the window and everytime I clicked close or generate report or cancel a new window with a new error code would take the place of the preceeding window. I once again had to close the generate report window in my system manager The escalation was found when I opened up FF and a message appeared informing me that the filter I had been working on was not formated to be readable. Everytime I open FF I get this message. I hope this is helpful in the future development of FF, and if you have any questions let me know. P.S. It is strange because it comes back saying the invalid file is 0KB big but it is still on my computer? Another bug? I tried to attach it but since it is 0 kb Big I can't. |
| Posted: June 20, 2007 1:06 pm | ||||
Yeah, I don't know exactly what causes it, but many have experienced it. I would suggest going under the FF hood and frequently backing up everything in "My Filters" to another file.....or creating copies of it in "My Filter" as you go.....especially after completing significant work that would be hard to re-create......
You can usually tell when it's about to happen.....mouse cursor starts to hang up and rendering starts to get slow. Sometimes when you start to run into it, closing and restarting FF will remedy it..... Steve
| Posted: June 20, 2007 1:35 pm | ||||
| ssamm |
I've noticed that if I worked on or left FF on for long amounts of time it tended to do that bug more often. Now I make sure it's closed whenever its not in use (and actually have only been making relatively quick and filters as of late) and I haven't had this problem for a quite a while. But I still make multiple versions of the same filter (e.g. "blur1a" and a renamed, "blur1b") just in case one gets corrupted...
| Posted: June 20, 2007 10:46 pm | ||||
Administrator |
This is probably caused by a resource leak bug, which has been already reported many times. We're still trying to reproduce it.
| Posted: June 21, 2007 4:24 am | ||||
Administrator |
This is normal -- the file was created empty (0 bytes) but nothing has been writen into it due to the bug. Just delete it. |
| Posted: June 21, 2007 4:25 am | ||||
Redcap
One last question, when I get the bug generate report it is very difficult to close. If I try to close the generate bug report window a new error window with a new error appears. Is that a common bug as well? Would you like some of the error codes or is it not really important because you already know exactly what I am talking about?
| Posted: June 22, 2007 4:58 pm | ||||
yes, the multiple reports often accompanies the resource leak bug. i've gotten as many as 120 error reports from one crash. just keep clicking the 'X' and they'll eventually go away.
| Posted: June 23, 2007 10:50 am | ||||
Well I will post this filter I have only started on and getting the old mouse thing. So I will post it in hopes that it will help to track down this crazy bug that hides..
One other thing I don't know if this is releated or not but I throw it out anyway. But I am also networked with another computer sharing a internet modem. There is always activity between the two computers.. Mouse slows.ffxml Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: June 24, 2007 2:37 am | ||||
CF, i dont think this resource leak thing is related to any one filter. i believe it's a windows thing. and more than likely isnt an FF bug at all, but rather a windows bug that simply shows up through FF.
| Posted: June 24, 2007 11:48 am | ||||
Redcap
It might be a computer thing, because everytime it has happened to me was when I was listening to itunes, working on a lot of complicated filters, and going really fast between different presets or filter settings. You know when the sample image looks like a collage of 12 different filters because it hasn't had enough time to load the whole filter.
Anyway, it may just be my computer is to old and slow... Maybe; however, this needs to be addressed by filter forge; because not everyone has dualdrives or better. |
| Posted: June 25, 2007 2:40 pm | ||||
i dont think so, redcap. it's resource management thing with windows. and mostly related to ram handling. ram gets fragmented with use. it's just like with a harddrive that gets fragmented. windows has no real good way to clean or de-frag the ram. so, after a lot of use it gets so bad that it finally sort of blows up.
there are ram flushing utilities out there that can clean this up. you can also just kill FF and restart it and that will help. that shld always be done when you start to see the mouse jerk and lag. you can also sometimes tell it's coming when you see your harddrive light start coming on a lot. that often means your virtual mememory/swap file is being used as ram and that tells you that your ram is basically in full use. getting more ram will also help, but only in delaying this inevitable occurrence, since you now have more ram space. but, with enough use, it will still end up fragging. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 25, 2007 2:57 pm | ||||
Redcap
I am not even going to pretend I know more than a smudge about computers, I only took 2 programming courses in college and that is about it. So I think you are completely right. I think the only abnormality of my bug with everyone elses is my mouse doesn't get laggy, it is just a sudden jump to ERROR. It is nice to know that FF rocks and windows is the one who needs help
| Posted: June 25, 2007 4:16 pm | ||||
