kurt
I wasn't sure if you wanted us to change your wiki. I was reading the documentation for
BLEND COMPONENT
Under Opacity the description was:
"Defines the degree of visibility of the foreground and background colors. The value ranges from 0 to 100. At Opacity of 0, the background is fully visible, while the foreground is invisible. Higher values of Opacity increase the visibility of the foreground. At Opacity of 100, only the foreground is visible."
This was not actually quite correct. (It is correct when the mode=Normal.)
"The foreground and background are blended according to the selected Mode. The Opacity defines the degree of visibility of the blend and the background. The value ranges from 0 to 100. At Opacity of 0, the background is fully visible, while the blend is invisible. Higher values of Opacity increase the visibility of the blend. At Opacity of 100, only the blend is visible."
Kurt -- thanks for spotting this! The help entry on blend is way, way outdated and it is basically a draft unchecked for facts -- we'll definitely rewrite it.
The Wiki is read-only for visitors, only our staff can edit it.
umm, where is the wiki? got an address?
craig
http://www.filterforge.com/helpwiki/
You guys should really open the Wiki up to editing by registered users.
Rixx
Rixx
smile;) PHP?
"What me officer??? You must be mistaken..."
It is linked via the help links within Filter Forge.
Kurt, Uberzev: Glad to see you're willing to help us with the documentation.
Let's discuss it here, and I will transfer your brilliant thoughts into the wiki smile:)
33,857 Registered Users
+44 new in year!
101 unregistered users.
